On my 88 kx250, I'm having trouble removing the right hand exhaust valve. I removed the the operating valve plug and pushed the operating valve all the way in but the right hand exhaust valve won't budge. The idle gear and left hand exhaust valve came out with ease.
Any suggestions before I give up and put it back together? |
#5 (permalink) | |
#6 (permalink) |
Hey, lemme ride your bike
We are talking about the same thing. Were the subvlaves all gunked up with carbon? It may have been carbon stuck. Brief periods of E-Z Off oven cleaner may have helped.
I hope you get it fixed. |
#7 (permalink) |
The dealer removed the guide for me. They charged $40 bucks
The worst part of the deal is I wanted to have the bike running for the 4th but I lossed the dowel pin for the cylinder head. Guess I'll have to wait till wed to order it |
#10 (permalink) |
Cylinder Guru
The main cause of your valve being jammed is CHEAP premix oil. Make sure you use a good synthetic. I recommend any that are rated 800 2T. Motul is my favorite. Instead of a hard carbon build up, synthetics will remain runny and allow for smooth operation. The actuator is steel but the two spindle valve are aluminum and if one or both valves lock up, the Kawasaki has no safety mechanism to prevent the spindle from having the teeth damaged on it. Check the teeth on your valves before reassembly.
Remember... most 2 stroke dirtbike owners manuals recommend a re-ring every 10 to 15 hours of race use. Cleaning the valves when pulling the cylinder down is a good habit to get into. |
#11 (permalink) |
Thanks for the tip. I just bought this bike. Right now, I'm using Bell synthetic.
The teeth were worn on the pinions. Is the little lever coming out of the base of the engine near the water pump suppose to move with the rotation of the engine? I'm reffering to the one that stands vertical and attaches to the operating rod. I don't think mine moves at all. |
#13 (permalink) |
Cylinder Guru
KDXGarage is right... it is centrifugally activated and the motor pulls that rod with great strength. You probably won't get that to move with your hand. The zing that occurs at about 1/2 to 2/3 throttle is that arm opening the powervalves to give you that top end power. If you don't experience that, then chances are it isn't opening the valves.
Conversely, the PV's themselves should be easily opened and closed by hand when you pull and push the actuator. Note the timing marks when reassembling and visually inspect that the valves open and close fully and simultaneously. I've replaced many of those spindle valves at about $60 a piece. |
#14 (permalink) |
Without looking at the service manual, I would not know for sure, but one some models, you can take the right side (as sitting on the bike) cover off and see if the rod moves. It would be around 2/3 RPM. That does not mean that the internal teeth are lined up properly or that the other valves are working properly, but it might be SOMEthing to check.
| Quiet Pipes | Zukdriver | Kawasaki Cruisers | 15 | 04-03-2009 04:29 PM |
| Exhaust Servo Motor Eliminator Install | Kawapowa | FAQ'S | 3 | 09-18-2008 07:27 PM |
| zx10 exhaust flapper valve | kawiboytwo | Kawasaki Streetbikes/Sportbikes | 6 | 04-28-2006 01:10 PM |
| 1989 kx 125 Exhaust valve | platinum | Accessory Swap Meet | 3 | 11-28-2004 10:51 PM |
| 1989 kx 125 Exhaust valve | platinum | Kawasaki Motocross and Offroad | 0 | 11-28-2004 06:10 PM |
