Old 09-03-2006   #1 (permalink)
opihiman911
Default KX65 white smoke and locked up rear tire
I was out ridding with my son on his 2001 KX65, having fun on a wide open cane road. About an hour into our ride, my son was ridding in third or fourth gear wide open, doing 25+MPH when suddenly his bike let out a HUGE belch of white smoke, then a second or two later his rear tire locks up and he is sliding fishtailing to a stop (wish I had my camera, his eyes were as big as plates, his little heart was going faster then his bike, so scared he was studdering). Got him calmed down and took a look at the bike.
A little white smoke was still coming out of the pipe. Rolled the bike back and forth, back wheel rolled. Carefully kicked it over, the engine turned over. Took out the plug, I could feel compression and suction with each kick. Plug looked good, nice tan/gray color with a good spark. Used an allen wrench to confirm the piston was moving up and down properly. Had coolant, engine oil was good not contaminated with water. Engine didn't seem excessively hot.
Put everything back together, kicked it over and it started up, but sounded terrible. Had a deep boggy sound instead of its normal high pitch pop-ping. Thick white smoke out of tailpipe. Also had a definate clack/rattle on the right side. Shut it down immediatly.
It took 20 minutes of convincing my son we had to tow it back to the highway with him ridding it. He wouldn't let me get out of first gear, kept on dragging the brakes, suprised my bike didn't overheat. It towed fine while in neutral, got back to the truck and back home. By the time we got back home, did my boy have a wild story to tell mom (and did I get some dirty looks).
Where do I start looking? My guess was a siezed piston when the rear tire locked up. But the piston is moving freely. A blown ring?? I would assume I need to rebuild the top end, but wanted other peoples opinion before tearing it down.
BTW this is pretty much stock KX65. I've only added boyseen power reed and a flywheel weight to tame this little beast and make more tractable low end. I have been using 32:1 MC1 oil with premium gas. Have always let the bike idle warm up for 5 minutes before ridding.
Any help appreciated.
Aloha,
Cory
opihiman911 is offline   Reply With Quote
Old 09-04-2006   #2 (permalink)
SNOWSTORMRIDER
My son rides the KX
Default steps to take
1. Drain all the coolant from the 2 bolts (cyl head and water pump)
2. Remove cylinder bolts 1/4 turn at a time in a criss-cross pattern.
3. Grab the connecting rod and check for play in botom end bearing.
SNOWSTORMRIDER is offline   Reply With Quote
Old 09-04-2006   #3 (permalink)
Sledder
Sledder's Avatar
Many reports of 65's throwing cranks. I haven't had it happen yet,but lots seem to have it happen.
I would pop open the top end and see if you just scuffed a piston,but also check the crank and rod bearings. I thought I read somewhere that the 07 model has"new bigger and more rollers on the rod bearings" or something to that effect.
04 MS 1640
Thunder 100 in kit/cams
Race ported heads by "dynoray"
Thunder air
V&H Propipe
PC3
Sledder is offline   Reply With Quote
Old 09-04-2006   #4 (permalink)
1400pilot
UBER CLUB MEMBER #2
1400pilot's Avatar
I would say that the bike scuffed a piston,, but do as Sledder said, check the crank brgs, as there has been some crank troubles, had to put a crank in my sons 65
Click for a map of the states I've ridden in
08 ZG1400 Concours
06 KDX200
04KX65
1400pilot is offline   Reply With Quote
Old 09-04-2006   #5 (permalink)
XR893
Uncle Bob's Love Child
XR893's Avatar
I think its the main bearing on the right side thats why you're getting the white smoke.I had a kdx 200 that did a main bearing and it also locked up (but on the road at about 70ks with my friend riding it in traffic!!!!!) but the next day it started too but sounded like a cement mixer!!
XR893 is offline   Reply With Quote
