I just picked up an 03 kx125. I'm having an extremely hard time starting it when its cold. It takes way longer than is normal. Once i do get it started, I have to keep the throttle up, or it will bog out between shifts. What can I do to fix this. The previous owner told me it has about 13 hours on a fresh rebuild. Any help will be greatly appreciated.
Zach |
2Stroke 4 life!!
First off is the choke on when starting it cold? Just a few other things that could be wrong is a dirty carb, air filter, bad reeds or even bad fuel. I would start with checking the plug and it's condition and do a compression test. There should be about 125-145 psi on the cylinder. If it has about 13 hours on a new top end it should be closer to 145+ psi. If those are good then check the condition of the air filter, but I would install a new or cleanly oiled filter. If the filter is dirty then while the filter is out I would remove the carb and clean it out and check the condition of the reeds. Yes this is alot of stuff to do but I do it all the time to make sure my bike is running in tip top shape.
86' 250R Trike 88' LT500RJ Quadzilla My blood is yellow and red! |
Choke is on when starting it cold. I'll clean out the carb tomorrow before i ride. I just put on a new air filter that i got with the bike. The old one was terrible. I'll check compression as soon as I pick up a compression tester. Plug is new though. I appreciate it. It started a little quicker today though so that was nice.
| Won't start sometimes? | rdiggidy | Kawasaki Streetbikes/Sportbikes | 11 | 08-25-2006 03:36 PM |
| Please help 89 KX125 wont start!!! | Jimbo RoX! | Kawasaki Motocross and Offroad | 3 | 10-01-2005 03:24 AM |
| 97 kx125 clutch issues | theshark | The Mechanics Corner | 4 | 09-17-2005 01:53 PM |
| 82 KX125 no start | mothertrucker | Kawasaki Motocross and Offroad | 4 | 06-21-2005 04:07 AM |
| 95' zx6r cold start takes very long | sin5150 | The Mechanics Corner | 3 | 04-22-2004 12:12 AM |
