Old 02-20-2007   #1 (permalink)
eazy89
Default KX65 Gear ratio Question
My son races a 07 kx65 and I changed the gearing to a 49 rear with a 13 front. This seems to be working well considering he can ride in 3rd/ 4th all day except 5th on the straight aways. It really has imrpoved his control in the soft sand which we get a lot of in floirda. Team green recommends a 14 front with a 46 rear. This gives the bike a lower gear ratio with more top end I'm assuming. Do you think the bike will get better track performance or speed with a lower gear ratio? Most the tracks we ride are soft, curvy, without alot of straight aways. Any suggestions?
eazy89 is offline   Reply With Quote
Old 02-20-2007   #2 (permalink)
metric sprocket
Hi pal sorry you did not change anything except sprockets.Rule of thumb,1 tooth in front eq. roughly 3 in back I dont know what stock gearing is on the kx. But i know a soft course lots of straights,sand,I would go up a tooth in front no sence in spinnin your wheels.Sorry I just reread your post <with out a lot of straights> I'd go stock gearing If he's not tacking out in the straights.Any thing I can help with just whistle,Went through this with both my own boys .enjoy while it lasts Ron
metric sprocket is offline   Reply With Quote
Calculate top speed from gear ratio. naoki Main Lobby 10 08-29-2008 02:44 PM
Gear Ratio Change tingboy The Mechanics Corner 3 11-01-2005 08:51 PM
KX65 jumping out of gear. Please Help. thehardway The Mechanics Corner 1 11-15-2004 08:28 PM
2004 500r gear ratio Homeguard Kawasaki Streetbikes/Sportbikes 7 11-12-2004 03:50 AM
Question on some gear.. comeback_kid96 Kawasaki Streetbikes/Sportbikes 15 03-24-2004 12:29 PM
