Old 02-28-2007   #1 (permalink)
KDX220(1997)
1997 KDX 220
Send a message via MSN to KDX220(1997)
Default NEED HELP - Wheel bearings
Hi i asked around on this site about some side to side play in my wheel , and i was told to take the wheel off so i did and and it is def not the swing arm , and when i put the wheel back on it is the wheel that has the play , so is that the bearings? and how do i check that to make 100% sure that it is , and how much damage could a very slight bit of play do if i ride it?
KDX220(1997) is offline   Reply With Quote
Old 02-28-2007   #2 (permalink)
kawah1c
Way Too Much Free Time
kawah1c's Avatar
Are all the collars and stuff there ? And not worn ?
kawah1c is offline   Reply With Quote
Old 02-28-2007   #3 (permalink)
freaKLX250
freaKLX250's Avatar
yeah mate you dont want to ride it if there is freeplay in your bearings
freaKLX250 is offline   Reply With Quote
Old 02-28-2007   #4 (permalink)
Kawoverthemoon
Finally Got Into First Gear
Kawoverthemoon's Avatar
might check to see if your spokes are tight, that can cause play in the wheel too.
if it is your bearings, replace them...they're cheap enough
Kawoverthemoon is offline   Reply With Quote
Old 02-28-2007   #5 (permalink)
KDX220(1997)
1997 KDX 220
yes all my shims and spacers r there and in good shape , i think im just going to replace the bearings , is that an easy job , seeming how i do not have the manual for my bike , and another thing if my spokes r loose , will they spin or wooble , how do i check that ? and where did you get that diagram from i would liek to have a look at some other things if possible , thanks for the help , its well appreciated
Old 02-28-2007   #6 (permalink)
Kawoverthemoon
diagram is from www.kawasaki.com . and the spokes you can just feel them. they should be solid like they're part of the rim and hub...like all one peice. if they're loose they willwobble or spin in your hand
Old 03-01-2007   #7 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
www.buykawasaki.com for the parts diagrams.
Put your finger on the inside of the inner race of the bearing and spin it. If it fels gritty or catches any during travel, it is definitely bad.
Have you got a long punch (pin punch) and a hammer?
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 03-01-2007   #8 (permalink)
KDX220(1997)
1997 KDX 220
yea i got about a thousand punches , from tiny , to really big , i got a full shed full of tools , why wat do you sugest ?
Old 03-01-2007   #9 (permalink)
kawah1c
kawah1c's Avatar
You just knock the bearings out from the opposite side of the wheel with the punch and hammer.
Wheel bearings jiffyjam Kawasaki Cruisers 2 01-02-2007 11:44 AM
V2K & Wheel bearing's NYcruiser Kawasaki Cruisers 17 12-19-2005 06:32 AM
frame polishing theorangezx-7r Kawasaki Streetbikes/Sportbikes 4 09-28-2005 02:22 PM
New Tires Balancing???? Bert Kawasaki Cruisers 9 07-19-2004 06:40 PM
Help with wheel wobble ('02 Ninja 500R) fhqwhgads The Mechanics Corner 3 05-19-2004 04:56 AM
