Hello All, This will be the first of MANY! posts here from Texas! So heres the story (short version) I grew up riding a 4 strokes just bought my first 2 stroke and i need to have some bottom end!!! I don't plan on taking it to the track its mainly to tool around with in the woods with my dogs. I know i should have bought a 4 stroke but this thing is sooo light i love it! Anyways i have been doing some research and i think i need the following items to give me som bottom end:
Front/Rear Gears Pipe/silencer flywheel wieght Carb rejetted/tuned does that sound right? If so what size/types should i buy? like smaller front gear bigger rear? or visaversa? Let me know what you think? Thanks Nick |
Jedi master
For your KX125,
1st, add one tooth to the rear sprocket, dont go down on the front, it is very hard onn your chain. 2nd Get a FMF Fatty and if you ride in a closed course, get a PowerCore2 Shorty. If you ride in a public area get a PowerCore 2 SA. 3rd Get a set of stiffer clutch springs. 4th Get a set of Boyesen Pro Series Carbon reeds(or a Rad Valve $$$ though). 5th If you can, get it ported for bottom end power. I have these mods on my 01 KX125(except porting), and I can tool around the woods and rip it up at the track with out changing anything. It gives you a very smooth, puched up, easy to use powerband. I have as much bottom end as my friends RM134, and I also have wayy more over rev power. It was definately better than stock.
'03 YZ250 '03 Kodiak 400 '05 YFZ450 I turned blue! |
So heres what i think
14 tooth front 50 tooth rear 9 or 11 ounce FWW FMF fatty pipe/silencer and then taking it to somone to jet/tune the bike Sound good? I was researching some and someone said "Heavy Clutch Springs"?? Would that help? I am also looking for help on suspension set up? I am 165 on a kx 125. Thank in advance Nick |
#4 (permalink) |
Jedi master
Your gearing you picked out would make it horrible in the woods! It would have very weak power and would go about 100mph! You should run a 12 tooth front sprocket, and a 50 tooth rear.
Try it without the flywheel first, I dont think youll need it. Mostlikely it will not need to be jetted, unless the last owner screwed it all up. Heavy Duty clutch springs are a must have. I dont remember where my clickers are at, (I wiegh the same as you) but I will go check them in a bit. When you buy your parts, dont forget to get a good helmet!
#9 (permalink) |
Another old dirt bike guy
Personally the first two things that go on our woods bikes are bark busters and a flywheel weight. The FWW makes them so much smoother and less apt to stall in the tight woods.
'05 KX85 w/'07 KX100 engine |
#10 (permalink) |
Jedi master
Yes, Bark Busters have saved my precious fingers quite a few times. Griff knows what he's talking about, go with the flywheel.
#11 (permalink) |
Cool so I think I will proably put the gear/pipe/reeds on first because the pipe is beat up and it still has the orignal gear and chain so it's time for a change then i will look into a FWW. But for the reeds do i need to buy just the reeds or the whole thing?
#12 (permalink) |
Jedi master
A reed cage will give you the most boost, but it is also quite pricey. Reeds themselves will also give you a power boost, just not as much as a full cage would. Unless you really want to spend $150 on a cage, I would say just get some carbon fiber reeds.
I put a Rad valve on my '91 RM125 and it gave it some nice power, but it is mostly mid and up power.
#15 (permalink) |
Jedi master
Looks good, you'll have to ask Griff on the FWW. I use EBC clutch springs. You can not get a Gnarly for a 125, they are only for 250's and 500's
#16 (permalink) |
Steahly should be able to recommend a weight for your purposes, but I will say this, the heavier the weight the more dramatic the effect. Steahly almost always list three different weights for most applications, I normally go with the middle becuase I want to actually gain something, but I don't like them to become to four stroke-ish if you know what I mean.
#17 (permalink) |
Thanks all I just realized that i spent way too much money this month so i think i will just go with the FWW for now and get the pipe and such next month. So i will let you know how it works out!
'01 KX 125 '97 Sportster 1200S |
| KX 80 engine into a 125 frame and some Q's | traskrider | Kawasaki Motocross and Offroad | 3 | 04-03-2007 09:38 AM |
| 2001 kx 125 cheap | theboss | Offroad Buy/Sell/Trade | 4 | 03-16-2006 04:47 AM |
| 2001 kx 125 f/s many extras | dirtbiker1410 | Offroad Buy/Sell/Trade | 3 | 12-11-2005 07:41 PM |
| kmxpetroil conversion 125 | johnsul | Kawasaki Motocross and Offroad | 0 | 09-05-2005 06:15 AM |
| 4 sale - 2001 YZ 125 | joey | Offroad Buy/Sell/Trade | 0 | 10-14-2004 10:47 AM |
