How do you make a KX65 faster, but stock legal?
+ Reply to Thread
Results 1 to 14 of 14
Thread: How do you make a KX65 faster, but stock legal?
  1. #1
    Foil Inspector BTK Beginner KBracing's Avatar
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    Default How do you make a KX65 faster, but stock legal?
    What things can I do to make my kids KX65 faster and keep it AMA stock legal?
    Thanks.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    Any advise from Team Green?
  4. #3
    Mat
    Mat is offline
    Join Date
    Feb 2004
    Location
    England, Kent
    Posts
    5
    Default Faster
    You can buy a little gizmo called 'Powerblade' that costs around £59. i dunno what it does but it works. you can see it here:
    http://www.dirtbikestore.co.uk/acata...Blade_149.html
  5. #4
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    Thanks. My brother uses something similar on his YZ250F.
    the big question is, is it AMA legal for 7-9cc stock class?
    Thanks again.
  6. #5
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    Any other ideas?
    Andrew #202 7-11 85cc advanced
    Kyle #041 7-11 85cc intermediate
    Frank #5 vets
  7. #6
    Still On The Kickstand BTK Beginner
    Join Date
    Dec 2003
    Posts
    48
    Sorry, no idea. When I took my son to watch the indoor motocross back in January, it seems like most of the riders in the 65 class were on KTM's. At least all of the ones out front were. I like the green bikes but am thinking about getting my son a pro junior/senior for next year, depending on his progression and desire.
  8. #7
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    I know what you mean. The KX65 is a great bike, but stock does not hold water to the speed of the KTM.
    I just bought my youngest a 2004 KTM Pro Senior LC.
    I think we will get a KTM 65 next.
    I can not even get anyone to help get the KX faster. You should see the KTMtalk website.
    Frank #5 vets
  9. #8
    Join Date
    Mar 2004
    Location
    Oxford,England
    Posts
    5
    Default faster
    lose mome weight. of the bike as well. it works
  10. #9
    Join Date
    Apr 2004
    Location
    southwestern, wyoming
    Posts
    7
    Default making little kawi's faster
    i'm not sure of the ama class rules but i see no reason why gearing wouldn't be the first choice. i'm pretty sure the tranny's in the ktm's are geared different than the gear ratios in the little kx's tranny. that should give you some leverage against any rule that would state that you had to use a specific sprocket sizes.so unless power delivery itself is the main problem gearing should work just fine.??any arguments or debates from you bored kawisaki folk's.or like mutley says put the kid on a diet.
  11. #10
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    My kid weights 65 pounds, that isn't the problem. He also has better clutch control than most novice/intermediate riders.
    You can gear all you want, legally. He is geared low enough that he starts in second gear. Just don't seem to get as much power as the KTM's. He pretty much doesn't have a chance on the start against the stock KTM's
    Now his modified KX is a different story. So I know it's not the rider.
    Frank #5 vets
  12. #11
    Join Date
    Apr 2004
    Location
    Australia
    Posts
    9
    Default hi my name is smithy
    take the head of ur bike and spray some w/d 40 down the head and into the cylinder it keeps the engince lubed and allows ur bike to revmore. ps try ****ting in ur fuel tank the methane gives ur powerband a much more powerful boost.
  13. #12
    Join Date
    Feb 2004
    Location
    Delta, Ohio
    Posts
    107
    You are a genius.
    Frank #5 vets
  14. #13
    Member BTK Expert
    Join Date
    Mar 2004
    Location
    Gardner, KS
    Posts
    2,159
    Default Gearing
    Gearing is probably one of the most important things to do. not only the countershaft sprocket but the rear sprocket as well. If you are not usig first and starting out in second then you obviously have the wrong gears on the bike. I raced a 175 Kawasaki 2 stroke on a real rrace track and in the end I was actually beating the other 175's and one of the two Honda Elsinores. Changing over to Synthetic AMSOIL 2 stroke oil and actually putting a splash of it in the tank will improve compression. get your carb set perfectly for the pipe and you can actually change the timing of your pipe (like karting does by adding in a piece of pipe between the motor and header pipe...lengthing or shortening it makes a big difference using the same expansion chamber. Seriously you can send a new pipe in and have it thermal barrier coated inside and it will improve performance as the gasses flow quicker and heat is not retained in the pipe. There are dry film lubricants that are applied electronically, do a little research. Then too tires and tire pressure play a very important role in performance. Make sure you find the lightest sprockets and chain...soak you chains in hot parafin wax then pull them out and let them hang to cool off and pull the parifine wax inside and have several chains, get rid of any dead weight that you are allowed to get rid of...can you get lighter tires or wheels...polishing the carbs inside for better airflow, use a K&N airfilter, find out if the front forks are bottoming out (use a nylon zip-strip) for measure in movement. same thing as the rear shock (you may have to change the fork springs or oil viscosity) is it illegal to run a 12Vdc muffin fan inside your airbox for extra bottom end...instead of having idle set at 1500RPM do what the big boys on the race track do and set you idle so that you have very little lag throttle power curve, increase it to 3,000 rpm you have a clutch and brake...If you are allowed remove the sponge foam seat and use the closed cell foam white stuff used in boats. 1" of the foam = about 4 inches of the yellow bike foam...
  15. #14
    Join Date
    Oct 2004
    Posts
    1
    Default Making your kx faster !!
    I HAVE JUST READ YOUR MESSAGES AND I I SEE THAT YOU NEED TO MAKE YOUR SONS KX FASTER. I AM 15 AND RIDE MOTOCROSS MYSELF. A FRIEND OF MINE HAS A YZ85 RACETUNED AND HE HAS NOT LONG COME BACK FROM AUSTRALIA AND HE SAID THAT YOU CAN BUY A RACE BLEND FUEL THAT MAKES THE POWERBANDS GIVE TWICE THE KICK. HE HAD SOME IMPORTED AN IT MAKES A HELL OF A DIFFERANCE. I HOPE YOU FIND A SOLUTION TO YOUR PROBLEMS. THANKS FOR READIN
    Sted_ed
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2004 KLX125 how to make faster than stock??
    By all muddy in forum Kawasaki Motocross and Offroad
    Last Post: 03-05-2006, 08:48 AM
  2. Replies: 44
    Last Post: 11-22-2005, 06:05 PM
  3. Stock parts from '03 Meanstreak 4sale
    By phlexit in forum Kawasaki Cruisers
    Last Post: 01-11-2005, 07:07 PM
  4. KX65 - What can I do to make it faster and be AMA legal?
    By KBracing in forum The Mechanics Corner
    Last Post: 03-08-2004, 03:30 PM
  5. How to make a ex500 faster?
    By Steve500r in forum The Mechanics Corner
    Last Post: 02-01-2004, 07:52 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
