Old 04-30-2007   #1 (permalink)
TRAMATBAY
Default 1992 KX 250 Front Forks, What matches?
I have a 1992 kx 250 and need front forks for the bike. What years will match/fit the 1992 kx 250?
TRAMATBAY is offline   Reply With Quote
Old 05-01-2007   #2 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
What is wrong with your current forks?
I know that 1991 - 1995 forks will bolt properly into the 1992 KX250 clamps, but the hub changed in 1993, so the axle mounting area MAY be different on the 1993 - 1995 models.
Be sure to check the front brake cable routing, as it is different on different years and may require a different brake cable and/or caliper.
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 05-06-2007   #3 (permalink)
TRAMATBAY
Broke from accident, not useable or fixable. I found a set on ebay from a 1992. Thanks for response.
ninja 250 wiring diagram-CDI ten The Mechanics Corner 6 07-12-2008 10:40 PM
Front brake problems placidfemme The Mechanics Corner 22 05-11-2005 10:07 PM
Will ZXR wheels fit the 250? makenzie71 Kawasaki Streetbikes/Sportbikes 4 02-07-2005 06:53 PM
Will 95 KX 250 front forks fit on a 98 KX 125? szewczyd The Mechanics Corner 0 02-16-2004 04:25 PM
95 KX 250 forks on 98 KX 125 ASAP szewczyd Kawasaki Motocross and Offroad 0 02-16-2004 04:24 PM
