Old 07-18-2008   #21 (permalink)
rjm350
I originally thought it was a bad seal letting trans fluid in, but I watch the level very close and I don't seem to be losing any trans fluid. The top end was fresh and it still did it so I don't think that is the problem either. The reeds are stock so they could be a bit old, it might be worth changing them.
Bones454 what elevation are you ridding at? I am anywhere from 3000' to 4500'. I have checked the plugs and it is getting plenty of fuel. I will try dropping a few pilot sizes once I have your elevation.
Thanks.
rjm350 is offline   Reply With Quote
Old 07-18-2008   #22 (permalink)
greenblur80
engine tech
i'd recommend rejetting at that elevation.if the reeds aren't sealing good it'll run alot richer
greenblur80 is offline   Reply With Quote
Old 07-18-2008   #23 (permalink)
rjm350
How does the Pilot jet numbering system work? Larger numbers = richer?
I think they come with a 45 in them from the factory correct?
Old 07-18-2008   #24 (permalink)
bones454
bones454's Avatar
990 feet above sea level,ga,thats why you may want to go down slowly on pilot,if you get one ride on a plug woods riding its way to rich if you get one ride riding motocross its to rich or you are a wimp.
bones454 is offline   Reply With Quote
Old 07-18-2008   #25 (permalink)
bones454
bones454's Avatar
My 92 came with 52 pilot but your elevation it will be higher I would drop pilot slowly till the plug is not wet and black.no need to worry about the main I do run boyesen reeds.I went down to I can ride with out fouling plugs but checked my plug often to make sure it was not to lean.If the plug is wet and black its to rich.
Old 07-18-2008   #26 (permalink)
bones454
bones454's Avatar
yes larger number richer,
Old 07-18-2008   #27 (permalink)
bones454
bones454's Avatar
As you drop a step at a time you will see the plug start to dry,you want a dark brown not black,my bike is so responcesive but not doing any damage to the motor,go back to the top of the jetting forum and if you can turn the air screw in without killing the motor its to rich.My bike is also set up at 40 to 1 honda hp2 or redline the two best oils,yamaha is good to.If anybody rides other than WFO try going down on the pilot once you get it the plug not so wet you'll see the difference.
Old 07-18-2008   #28 (permalink)
bones454
bones454's Avatar
Sorry 92 came stock with 58 pilot not 52.
Old 07-18-2008   #29 (permalink)
bones454
bones454's Avatar
WOODS WEAPON
Old 07-21-2008   #30 (permalink)
rjm350
Thanks for all the info.
I definitely need to drop the jetting, the plug is very wet and black.
You mentioned that you are running the stock Main jet. Since I got my bike used, and I'm not sure if the previous owner was messing with this carbs, what size of main jet should I be running?
Rj
Old 07-21-2008   #31 (permalink)
bones454
bones454's Avatar
yours main is a 160 or 162 and came with a 45 pilot,I would go in steps next size down on kawasaki parts list is a 42 pilot.
2005 Bayou 250 fouling plugs Elitefroggy Kawasaki ATV and Mule 6 08-21-2007 11:05 PM
fouling plugs ridingkx125 Kawasaki Motocross and Offroad 6 08-25-2006 01:57 PM
2003 kx125 fouling plugs dc4life20 Kawasaki Motocross and Offroad 6 01-30-2006 06:36 PM
02 800B plugs fouling rebelpeanut Kawasaki Cruisers 4 12-01-2004 02:16 PM
2002 KX 250 fouling plugs tahio1 Kawasaki Motocross and Offroad 3 05-11-2004 09:57 PM
