My 04-KX 125 build
+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 24
Thread: My 04-KX 125 build
  1. #1
    Join Date
    Oct 2007
    Posts
    19
    Post My 04-KX 125 build
    Hey guys i'm new to the forums and i would like to say hi and a pre-thank you to all.
    I first got my KX from my brother who lives in maryland and said if i came and got it, it would be mine for free. so i took a honda element and cramed the bike in all the way back to beautiful florida well i noticed the damages immediatly sence he left it in a so called friends trailer(you know how it goes from there).
    No air filter
    Blown top-end
    Kick assembly lever broke off
    clutch lever broke
    Sprocket and chain need replacement
    Rear Tire replacement
    ....but other than that its a free bike and i cant complain. i got a K&N air filter, rebuilt the top-end with a Wiesco Piston and Gasket kit. got all new levers. after the rebuild we went through the break-in but on the third stage the spark plug fouled out and we called it a day. before we went out the next day we changed the transmission oil to what at the time i didn't know was wrong, Specter gold 10w 40 4stroke! the guy at KAWI gave me the wrong stuff and i was to dumb to look myself. once we got the bikes off the truck i kicked the bike up and it started like a champ. but when i was going through the gears it would go 1st, N, 2,----transition to Neutral almost automatically. no grinding or anything it just feels like i lost 3,4,5,6.
    well after being crushed from what i saw as a failed rebuild and then having my son about 3 weeks later i stopped working on the bike.
    ...I've been doing some reading after i noticed i had the wrong oil and i dumped the transmission oil out a when i tried to go through all the gears
    1,N,2,3,4,5,6. i was looking like this i rushed to KAWI and got GearSavers75 got new spark plugs and filled up the tranny.
    tried the gears and i only have 1,N,2,-----Neutral!!!!!
    Whats wrong and what can i do. i can do some motor work but splitting the case is out of my department.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Now after another 125!! BTK Expert KickassKX125's Avatar
    Join Date
    May 2007
    Location
    Helmsley, North Yorkshire, England, UK
    Posts
    895
    Unless someone else knows how, i'm afraid your going to have to split the cases or send the engine off for repair.
    Are you sure it isn't going 1,N,2 then jumping back into N.
    Does it make any crunching like sounds when you try to change through 3,4,5,6?
    Jamie
    1996 CR250: IT LIVES!! and bloody goes aswell, lol!
    After another KX125 to kill the garden!
  4. #3
    Hey, lemme ride your bike BTK Expert KDXGarage's Avatar
    Join Date
    Dec 2005
    Location
    AL, USA
    Posts
    1,964
    If it was 10w-40, then I don't see that being a problem. Do you know for sure that it was shifting properly before the nice friend gave it back? I am guessing gear damage is also on the (what he did) list.
    Any chance you still have the drained oil? (to check for metal shavings)
    DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
  5. #4
    Join Date
    Oct 2007
    Posts
    19
    Thanks so much for the replys.
    1st queston:
    It feels like it just slips into N after trying to shift from 2-3. there is no grinding or noises what so ever. it feels like it was made to do that if you know what i mean. i guess you could say it jumps back to N.
    2nd question:For the first two break-in sessions it went through all gears smoothly just like it is supposed to.
    i've changed the oil twice no shavings or particles whatsoever. the first time was after the build i put the 10w40 4stroke oil by accident after the two break-in sessions. i know i should have changed it right after the re-build (but i didnt). it still ran very well. after that i put the gear savers 75.
    so with oil in it doesnt shift past second but with it out i can go through every gear with no problems at all.
    Thanks for all your help. it means alot.
    *someone told me the shift fork could have came out of place and all i would have to take the plate off and currect the misplacement. but with my luck so far this cant be it.
  6. #5
    Join Date
    May 2007
    Location
    Posts
    895
    Find a long straight and go from 1,N,2 and flick the gear lever up repietedly so that it wouldnt have chance to drop into N, if it does keep getting no propulsion after 2 then i would get the cases split and find out whats going on in there.
    If you sent it away for repair it could cost a fair bit, it would be better off doing a bit of D.I.Y.
    Jamie
  7. #6
    Join Date
    Oct 2007
    Posts
    19
    I'm thinking of just bringing the motor to KAWI and let them do the work. I'm stuck and the bike is just attracting dust when its begging me to ride.
    Does anyone know of a good shop in the Orlando/Central Florida area. I don't really prefer the dealer.
  8. #7
    Join Date
    May 2007
    Location
    Posts
    895
    I'm out of my depth there, I'm in UK not US, Sorry, i'll leave you to the US guys
    Jamie
  9. #8
    pre mix for blood BTK Intermediate
    Join Date
    Jul 2007
    Location
    kansas
    Posts
    150
    how does the clutch feel? i mean does it act like its tryin to pull the bike when you sit there idlein and in gear ? does it fell like its tryin to pull ....... i would even adjust you clutch lever so you have a little play in the lever prior to actually engagein the clutch ..... because if there is the slightest bit of drag on the clutch it can make it hard to hit your shifts all the way i went through this a bit with mine ( 03 kx125) and then i adjusted the clutch like i said above ................. promblem solved !!!!!!! but if you cant get it i have the actual kawasaki service manual just let me know and i can send you the parts of the manual you will need to fix it
    You better watch out ....." IM COMMIN AT YOU LIKE A SPIDER MONKEY "
  10. #9
    Join Date
    Oct 2007
    Posts
    19
    so i know its been a while but i now have time and money to put into the bike again....
    I know i just put up the " 2004 KX124 spark plug " thread but i thought i would bring the conversation to this one since my problem is with the bike as a whole instead of just the plug.
    so i got the correct plug today along with alot of other goodies but all for nothing. gapped it and then put it in. and went to kick it over and nothing. if i pull the choke and kick i get no noise. if i kick it WOT then it makes a sputter sound as if it trying to turn over or as if you ran out of gas(trying to give you guys an example) what i don't understand is why it wont start if it was running perfect after the rebuild. what could it be?
    now....the past problem with it the engaging in third may be resolved but i cant get the bike to even start. a member from this forum had the same problem and you guys will not believe what it was. oil drain plug GASKET wow yes a $2 piece put my transmission out of commission. but i still dont know if that will totally solve my problem since i cant get it to start and test it out.
    so heres a list of the rebuild:
    Kawasaki Kickstart assembly
    Kawasaki Air box assembly
    K&N air filter
    Wiesco top end
    Cometic gasket kit
    Renthal grips
    all new levers
    all fluids refreshed
    ***Now on hold until the bike is running properly***
    Primary Drive Alloy Kit & Gold X-Ring Chain
    FMF Gold Series Pipe
    FMF Turbine Core II Silencer
    Tires
    Thanks for all the help you guys have provided me on this forum and hopefully we can jointly fix my problem. Mike.
  11. #10
    Join Date
    Oct 2007
    Posts
    19
    took the carb off last night and took pics of the intake and exhaust. it looked clean if that means anything. took the bolt off the bottom and fuel was in there, it was also clean.
    do you guys think the jetting could keep the bike from starting?
  12. #11
    curiousity_killed_the_cat BTK Beginner 05kx125's Avatar
    Join Date
    Jan 2008
    Posts
    94
    if its not starting and you dont know what to do, then just push it and jump start it if it doesnt run (which it should even if it had 1 year old fuel) then something is up. thats what my buddy did. didnt start his bike for a year and hid little gas in so i pushed it and he jump started in 2nd gear thing started up pretty easy but ran like crap cuz the gas was like 80-1 becuase it was old...
    04 kx125
    sold 05
    99 cr125
    03ktm525
  13. #12
    Wants better weather! BTK Expert stevied645's Avatar
    Join Date
    Nov 2007
    Location
    Scotland
    Posts
    731
    Quote Originally Posted by Scream N KX125 View Post
    What do you mean, i just dont get why that would stop it going up the gears. Or can it??
    KX250/500 Hybrid LOL Scary Stuff
  14. #13
    Join Date
    Oct 2007
    Posts
    19
    Quote Originally Posted by stevied645 View Post
    first: its not that it wouldnt go up in gears its that it wouldnt engage third therefore not allowing access to 3,4,5,6.
    its not a fact that it fixed my problem since i haven't got the bike to start and try it out. but his symptom's were identical to mine with the exact same bike and i happened to be missing the same part the he described as what fixed his bike.
    also when i was changing oil to figure out what was wrong the bike i would go through every gear smoothly with no problems with out oil. but with oil it wont engage third. No oil no gasket or plug. with oil = just a plug since i misplaced the gasket. assuming the drain plug was in just enough to obstruct 3rd from engaging. Mike.
    *now that i think of it i can see if it worked by just pushing and shifting. i'll keep you up to date. gotta wait till my toddler takes a nap so i can work on the bike once again.
  15. #14
    Full Circle Rider BTK Expert SixFiveOh's Avatar
    Join Date
    Apr 2006
    Location
    Katy, TX
    Posts
    1,611
    That would indicate that the oil plug was long enough without the gasket to interact with a moving part in the transmission. The interaction causing the trans to bind. Not sure I'm convinced this would be the case, but if it works, it works.
    Keith
    '07 Lime Kawasaki KX450F
    '06 Red/Black Suzuki Hayabusa
  16. #15
    Join Date
    Oct 2007
    Posts
    19
    Cool
    Quote Originally Posted by SixFiveOh View Post
    i can only hope.
    but, if not once i get the carburetor back together if its not running like the champ i know it to be its going in the shop and i'll fork over the cash. i need to ride.
  17. #16
    Join Date
    Oct 2007
    Posts
    19
    so when i was i was removing a screw from the float bowl i stripped it. it just keeps getting worse.
  18. #17
    Join Date
    Nov 2007
    Location
    Scotland
    Posts
    731
    +1 cant see it myself but if it works it works
  19. #18
    Newbie alyssakx's Avatar
    Join Date
    Sep 2008
    Location
    Blasdell NY
    Posts
    1
    The same problem occured with my bike a while ago. Only 1 2 & N were there. After 2 it would simply lock up. After splitting the engine completely... we discovered I must have cranked the drain plug too hard & over time it stretched, preventing 3rd & up to click in. I had never heard of that occuring before and neither had the guys at the shop I go to. After having to put the engine back together ..ugh and replacing the drain plug it worked great... yeah it does happen so make sure your not cranking too hard on that plug. I learned the hard way.
  20. #19
    Join Date
    Oct 2007
    Posts
    19
    It's been a while since I touched the dirt bike. I cant get it to start and after buying a '05 zx6r I've had little time. I plan on working on it soon. i get spark but the bike just wont start. I need to read and just try everything i can.
    *Nothings Free*
  21. #20
    gaz
    gaz is offline
    Uncle Bob's Love Child BTK Intermediate
    Join Date
    Apr 2006
    Posts
    252
    If you are going to split the case, you can save heaps by stripping the motor down to the stage where you are about to split the case then take it to the shop. I did this when I needed a new crank. They only charged me 100 bucks to install the crank/bearings and seals that I supplied and reseal the case. Also when taking the clutch hub off you can see the gear ratchet assembly and you can make it go through the gears and see whats happening. This is a last resort if nothing else works.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 1991 kx 125 fork
    By ptownford in forum Kawasaki Motocross and Offroad
    Last Post: 01-12-2009, 01:53 AM
  2. KDX 200 Engine in a KX 125 Frame
    By knickk in forum Kawasaki Motocross and Offroad
    Last Post: 08-26-2007, 04:42 AM
  3. 125 vs 250
    By old kxrider in forum Kawasaki Motocross and Offroad
    Last Post: 02-22-2007, 12:33 AM
  4. 05 125
    By KX_125 in forum Kawasaki Motocross and Offroad
    Last Post: 07-31-2005, 11:18 AM
  5. can i put a 1984 kx 125 motor in a 1987 kx 125 frame
    By st3 in forum Kawasaki Motocross and Offroad
    Last Post: 07-08-2005, 01:23 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
