Old 01-24-2008   #1 (permalink)
03kx125
Default crank seals
would you have to split the case on an 03 kx 125 to do the crank seals becuse one looks popped out of place and would like to replace it i didnt see any lip to hold it there, and would it lean out, backfire and foul plugs if one was a little out of place because it did that and then it just quit.
03kx125 is offline   Reply With Quote
Old 01-24-2008   #2 (permalink)
FPMXer
2Stroke 4 life!!
FPMXer's Avatar
Yes the engine cases need to be split to install new seals. If a seal is blown out then there is another underlying problem. While your in there you might as well replace the crank bearings and check for other issues.
86' 250R Trike
88' LT500RJ Quadzilla
My blood is yellow and red!
FPMXer is offline   Reply With Quote
Old 01-24-2008   #3 (permalink)
griffbones
Another old dirt bike guy
griffbones's Avatar
+1 Bad main bearings is the number one cause of bad main seals, that is next to improper installation.
'05 KX85 w/'07 KX100 engine
griffbones is offline   Reply With Quote
Old 01-24-2008   #4 (permalink)
03kx125
it couldnt be the main bearings because it was apart and they were like new quiete and smooth
Old 01-25-2008   #5 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
It sounds like faulty installation may apply here.
Is there supposed to be a certain gap left on those?
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 01-27-2008   #6 (permalink)
03kx125
well me and my mechanic had it apart to put new gear in tranny it ran great when it went bak together but bout a week after it started to act up so i took the side cover and clutch off and revealed it was out of place, i gave the carb to my mech and he bumbed the jets up but before i put it back together i hit that seal back in to place then put the carb back on ran good but a lil rich so put stock jets back in and runs good so im thinkin it was that seal just poped out of place
Fork Seals... OEM or Aftermarket? dsmack Vintage Motorcyle Info 1 07-07-2007 02:41 PM
2004 KX65 crank seal Paul_B Kawasaki Motocross and Offroad 2 05-29-2007 07:42 PM
no crank intermitant ex250 06ninja250 The Mechanics Corner 3 12-06-2006 05:23 AM
1992 kx250 crank seals???? broncokawi The Mechanics Corner 1 09-29-2006 08:23 PM
mule 2510 crank bearings ssmule Kawasaki ATV and Mule 0 11-30-2005 06:12 PM
