Old 03-03-2008   #1 (permalink)
kx all the way
Made It To Second Gear
Default type F transmission fluid or oil?
should I use transmission fluid or oil in my kx 100 and my rm 80. Is it better in the clutch or not. Does it make it run better? Is my kx 100 supposed to have transmission oil in it? I put sae 10-40w in it and the clutch keep slipping. It had oil in it before.
kx all the way is offline   Reply With Quote
Old 03-04-2008   #2 (permalink)
leaper
use normal motorbike gearbox oil.
leaper is offline   Reply With Quote
Old 03-04-2008   #3 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
NO!!!!! F type oil solves EVERYTHING!!!!!!
Just kidding. Try a motorcycle oil for your motorcycle.
DO NOT e-mail me asking for a pdf of a manual!! Get a Freaking JOB like I did, and buy one!
KDXGarage is offline   Reply With Quote
Old 03-05-2008   #4 (permalink)
RichLockyer
RichLockyer's Avatar
ATF's primary purpose is as a hydraulic fluid.
It is good for the clutch (basically the same type of clutch used in an automatic trans), but it's not so good on the gears in a bike. Automatic tranny gears are completely different... helical cut, planetary gear sets...
Stick with the factory recommended weight and type of oil.
- Rich
2006 1600 Ultra-Classic
Patriot Guard Rider
Old 03-05-2008   #5 (permalink)
damonkmx125
Finally Got Into First Gear
lol i use 5w30 transmission oil in my kmx125 and once ii ran out so i put ATF in it and was liike my gears were stuck together with syrup woops
damonkmx125 is offline   Reply With Quote
in the mail - Vulcan 2000 Oil Level Check Procedure Spok Kawasaki Cruisers 22 11-05-2008 12:19 PM
Is 900 transmission quieter with synthetic oil? BikerEm Kawasaki Cruisers 16 09-04-2007 09:23 AM
oil type yoy Kawasaki ATV and Mule 1 09-02-2007 10:46 AM
Whats the best type of oil? Desp Main Lobby 1 12-25-2003 09:09 AM
type of oil? Kawguys The Mechanics Corner 1 12-10-2003 02:33 AM
