i have been searching the net cant find so i thought id ask here
what is the stock sprocket size on a 2007 kx250? i had a kx250 05 model first bike in 10years i gave it up for a 4bangger wich i dont like i only gave up the 2smoker cause i had a really bad accident on it then was afraid of it but i miss the 2smoker so what tricks are there that i could tame down a kx250 2smoker Problem is with my 05 model the front end was always comming up i couldnt keep it down most of the time i like speed more then raw power but i like a good combination what size sprockets would you guys reccomend riding style just trails odd jump just mainly to have fun nothing serious so basically what can i do to tame the monster i dunno if my old 05 had the stock size sprockets or not as i dont know what size they came with Thanks |
Wants better weather!
go to kawasaki.com and go to the parts diagram it will tell u there,
I run a 12t front and standard rear on little tight tracks but run a 15t front on long dirt road rides 15t is really tight to get chain on though, i think standard is 14t but mines is a 96 dunno if they would be differant. i think 1t down on the front is supposed to be equivelant to 3 up on the rear
KX250/500 Hybrid LOL Scary Stuff
Tree Magnet
13/51 is stock. if you want to tame it, and won't be racing, you could go with a 14 in the front or a 48 in the rear to make each gear a little taller and make the hit a little less abrubt. A flywheel weight is THE ticket for these bikes.
#4 (permalink) | |
yah i was just looking at the flywheel i see some huys dropping a tooth or 2 on the back plaus adding a flywheel weight what size flywheel weight would you reccomend not for racing bike but just an everyday bike but i will do add jumps and such i have a yz250f and i hate its guts regret getting rid of my kx250 my neighbor has it now iam going to grab another kawi on the weekend 07 kx250 and throw a flywheel weight flywheel weight sizes are 7 9 11 13 |
#5 (permalink) |
find out if a 96 flywheel weight fits ive got one here (stealhy) ill find out what weight it is. and let me know if ur interested (its practically brand new only a couple of marks on it)
#7 (permalink) |
Jedi master
I would drop 2 teeth on the rear, add a flywheel, and switch to a FMF torque pipe. That should tame it down a bit, and the pipe should move some of the top end surge down to the bottom where you will use it.
'03 YZ250 '03 Kodiak 400 '05 YFZ450 I turned blue! |
#8 (permalink) | |
Now after another 125!!
Jamie Bought 1996 CR250 but need to pick up. Now after another Mad Kaw 125 to tear the garden up! |
#9 (permalink) |
curiousity_killed_the_cat
im using an 10oz on my cr, with 14t front and 55 rear. smooth but lots of traction acceleration takes a bit to really pull though.
now im running a 14 tooth front and 55 rear is more teeth slower top speed and faster acceleration or more top speed and less acceleration?
04 kx125 sold 05 99 cr125 03ktm525 |
#10 (permalink) | |
Jedi master
Oops, forgot to put flywheel weight! Quote:
| Sprocket size? | 2stroke173 | Kawasaki Motocross and Offroad | 15 | 11-05-2007 07:50 PM |
| Sprocket Size | SribbuCC | The Mechanics Corner | 1 | 05-04-2007 05:36 PM |
| KX65 Front Sprocket/Rear Sprocket Size | sd_outkast | Kawasaki Motocross and Offroad | 2 | 11-09-2005 02:55 PM |
| Stock sprocket size? | theshark | Kawasaki Motocross and Offroad | 3 | 09-26-2005 09:42 AM |
| KX250 99 Clutch Hub Bolt Size | 1mach1 | Kawasaki Motocross and Offroad | 1 | 02-23-2005 09:41 PM |
