Old 03-20-2008   #1 (permalink)
duckunter
Cool Exhaust valve removal & clean up
I am trying to disassemble my exhaust valve so I can clean the carbon from it. It is a 2000 KX 250 and I would guess it has never be taken apart and cleaned. (not the original owner!) I can't get the idler gear or secondary exhaust valves out of the cylinder block. I'm sure they have a lot of carbon built up on them. Any suggestions on how to get them out without tearing up the metal on the shaft of the gears??? If I scar the metal and file it smooth again will it hurt anything? Open to suggestions.
duckunter is offline   Reply With Quote
Old 03-21-2008   #2 (permalink)
2stroke173
Clutch Cadet
2stroke173's Avatar
The clymers manual for my bike says "If you must use force to remove them, first wrap the shafts with a piece of shim stock (not sure what that is) or similar material. Doing so may help prevent damages to the shaft surfaces."
Maybe you can use compressed air and direct it to the exhaust port for the secondary valves (where it opens and closes port) and that will pop them loose...I just removed, cleaned, lubricated, re-installed the exhaust valves on my 93 kx125
2stroke173 is offline   Reply With Quote
Old 03-21-2008   #3 (permalink)
#34 KX 250
The original #34
#34 KX 250's Avatar
i agree with 2stroke173
C.Norberg #34 Monster Energy Kawasaki KX250
#34 KX 250 is offline   Reply With Quote
Old 03-22-2008   #4 (permalink)
condon66
Finally Got Into First Gear
Shim stock is very thin metal sheet. It can be bought in varied thicknesses like .003 or .010. We use brass shim stock when needed. The idea in the Clymer manual is to wrap a piece around the bottom of the exhaust valve so that you can grab it with a pair of pliers and tug. The shim stock prevents damage to the surface and is flexible enough to wrap around the valve. Just keep working at it and be patient. They will come out.
2000 KX 250 Excel hoops, Pro Circuit exhaust, Factory Connection suspension.
condon66 is offline   Reply With Quote
Old 03-23-2008   #5 (permalink)
duckunter
Thanks for the input! I let some engine degreaser soak in/on them for a few hours and I was able to pull them out. (with vice grips)
exhaust compatibility Roodawg307 Vintage Motorcyle Info 0 04-21-2007 12:55 PM
06 ninja 636 exhaust valve? sikninja636 The Mechanics Corner 1 02-21-2007 05:57 PM
kx 250 exhaust valve on back order beebe Kawasaki Motocross and Offroad 2 12-01-2006 12:47 PM
got my new old exhaust on.... 1hotz Main Lobby 3 07-16-2005 10:17 PM
2002 zx6r bill Kawasaki Streetbikes/Sportbikes 2 04-25-2004 07:59 AM
