2001 kx 250 starts up in full rpm
+ Reply to Thread
Results 1 to 4 of 4
Thread: 2001 kx 250 starts up in full rpm
  1. #1
    Join Date
    Mar 2008
    Posts
    1
    Default 2001 kx 250 starts up in full rpm
    i bought a 01 kx 250 today knowing it hadproblems, when you start the bike the rpms go throught the roof, okay, so i turn the fuel screw down, rpm's go down a little but still eratic at times, i start to think it must be a fuel issue. i check the pilot and main jet finding nothing and then the needle and seat, still finding no problem. my question is, if the powervalves are stuck wide open will this cause the bike to run at full rpms? is there a way to check the powe valves without taking off the head? am i chasing the wrong problem? i am new to this forum so any advive would be appreciated
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    Now after another 125!! BTK Expert KickassKX125's Avatar
    Join Date
    May 2007
    Location
    Helmsley, North Yorkshire, England, UK
    Posts
    895
    It takes about 15 kicks to start my 125 up it revs through the roof for about a 10 seconds and then takes its self back down to idle, it takes about 20 seconds to come back to idle. But after that as long as its warm it will start 1st kick and shoot off the moment you get into the powerband.
    I don't think its anything to do with the powervalves, but if you wnt to check take the linkage cover off, I dont know where it is on the newer style engines but on mine its on the R/H side of the barrel.
    Its more likely to be carb related.
    Jamie
    1996 CR250: IT LIVES!! and bloody goes aswell, lol!
    After another KX125 to kill the garden!
  4. #3
    Wants better weather! BTK Expert stevied645's Avatar
    Join Date
    Nov 2007
    Location
    Scotland
    Posts
    731
    Or lefthand crankseal related if its blown it revs sky high and doesnt come back down, the only other reasons could be sticky throttle cable or carb boot has a hole in it, if carb boot is fine and the slide in the carb is fully shut then it will prob be the crankseal, do a leakdown test
    KX250/500 Hybrid LOL Scary Stuff
  5. #4
    Still On The Kickstand BTK Beginner
    Join Date
    Feb 2008
    Location
    CA
    Posts
    42
    The powervalves is not your problem. You have an air leak somewhere after the carburetor. Since you said it was a 2001, the air boot is old and fatigued and therefore may have craks on it therefore causing your motor to lean out and then rev to the moon. The other reason is you might have a worn out ignition side seal, again, causing your to run lean and have erractic revs.
    Alex V[FONT="Comic Sans MS"][/FONT]
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. 2001 250 Ninja help with idle
    By brainscan in forum The Mechanics Corner
    Last Post: 06-22-2006, 05:24 PM
  2. 2001 Ninja 250 question/choke cable
    Last Post: 06-19-2006, 05:36 AM
  3. electrical failure in 2001 ninja 250
    By gman87327 in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 04-13-2006, 02:21 PM
  4. 2001 ninja 250 for sale !!!!!
    By jade404 in forum Streetbikes Buy/Sell/Trade
    Last Post: 12-04-2004, 05:25 PM
  5. Just got 2001 Ninja 250 need some advice...
    By blue blurr in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 09-26-2004, 12:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
