Old 02-20-2005   #1 (permalink)
used98KX
Finally Got Into First Gear
Default 98 KX starting problem
I need some advice, i'm not much a mechanic and don't know what is wrong.
Bike was behaving great for a couple of hours, i was taking it way too easy though due to riding with my kids on their atv. 100 yards from the truck we stopped for a second to talk, the bike died and wouldn't restart. This has happened before because of my slow riding and i fixed it by taking the cylinder head off and cleaning the gunky oil out of the valve so it would move freely. Doing that again did not fix this problem. I put in a new plug and took the carb out and sprayed it clean, after a bit the bike started then died again, i got it restarted later and it ran fine except for when i let off the gas then it died and took 5 mins to get it restarted, then it ran fine until i came to a stop again and the bike died and now won't restart.
I kick and kick and all that happens is it periodically (for lack of a better description) farts out the exhaust. It seems to me like i have some sort of carb issue but i have no idea how they actually work lol, I do have a diagram of the carb so i'll know what you're talking about if you can describe some things to try. Any help would be appreciated.
btw, this is a 125cc
used98KX is offline   Reply With Quote
Old 02-21-2005   #2 (permalink)
scottc1088
did you clean all the jets in the carb?
scottc1088 is offline   Reply With Quote
Old 02-21-2005   #3 (permalink)
used98KX
I sprayed it/them with carb cleaner the best i could without actually taking the carb apart.
Old 02-21-2005   #4 (permalink)
scottc1088
i would strip it down completely and clean it
also is the spark and compression?
Old 02-21-2005   #5 (permalink)
2WheelFun
the "fun old" guy
2WheelFun's Avatar
Possibly an electrical problem?
***KING KAHUNA***
***2007 V2K LT***
******PICS******
2007 Brute Force 650i
******PICS******
*I love the smell of SeaFoam in the morning*
2WheelFun is offline   Reply With Quote
Old 02-21-2005   #6 (permalink)
QKENUF4U
AZ's Official Mechanic
QKENUF4U's Avatar
being two stroke have the compression checked. sounds like the top end is gone.
also like stated above, might be worth your time to pull the carb down and clean the jets/internals. also make sure the air filter is clean, make sure the exhaust isnt plugged up somehow, make sure you have spark
QKENUF4U is offline   Reply With Quote
Old 02-21-2005   #7 (permalink)
used98KX
Will do
Old 02-22-2005   #8 (permalink)
used98KX
I ordered a top end rebuild kit today, we'll see how that does
Old 02-28-2005   #9 (permalink)
used98KX
Rebuilt the top end today. It's running great. Thanks for the advice!
Old 03-01-2005   #10 (permalink)
used98KX
She's still running good, starts on first kick, idles properly. I'm ecstatic
