Old 05-13-2008   #1 (permalink)
NATE HEAD MIAMI
Default Rear Sprocket Question
I Currently Have A Ktm 85 With A 37'' Rear Sprocket And My Cr 85 Expert Has The Same Rear Sprocket But My Ktm Seems To Always Have That Pull Away Speed Why Is The Bike Not Running Like My Ktm
MIAMI RIDER
NATE HEAD MIAMI is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
jandb917
pre mix for blood
jandb917's Avatar
well you have to take into account that every bike maker is diffrent
what i mean is diffrent engines have diffrent power bands sooo one may be real good one the bottom and one may be better on the top end
as far as speed all bikes are diffrent with the gearing in both the transmission and the sprockets .... so just casue they both are 85cc doesnt mean that the gearing is the same ....to make that cr pull like the ktm off the line you could go to a larger rear sprocket which will give it more torque but less top end .......
You better watch out ....." IM COMMIN AT YOU LIKE A SPIDER MONKEY "
jandb917 is offline   Reply With Quote
Old 05-14-2008   #3 (permalink)
NATE HEAD MIAMI
Thats Why I Changed It When We Line The Bikes Up To Race When I Had The 55'' On The Cr Which Is A Stock Sprocket It Jumps The Line All Da Time Long Stretch It Wines Out An My Ktm Passes Right By When I Dropped The Sprocket It Takes To Long To Catch Top Speed Likemy Ktm Is Just Right When I Try To See If My Cr85 Expert Can Hang With It I Guess Not But Why Does My Small Wheel Cr 85 Beats The Bike By At Least 1 Semi Truck Its Con Fusing To Me Lol
MIAMI RIDER
Old 05-14-2008   #4 (permalink)
jandb917
pre mix for blood
jandb917's Avatar
like i said diffrent makers have diffrent engines ....it sounds as if the KTM has a stronger power band and the gearing is right ... as far as th CR you may have went too far onthe sprocket change ..... but the gearing in the transmission also has alot to do with the top speed .... and the starting speed also
You just have to try diffrent gearing combinations on the sprockets and see what works best
Highside dynamics Bad Company What I learned today 11 08-02-2008 01:37 AM
rear sprocket bolts rubbing HELP! fitbmxseries1 The Mechanics Corner 4 06-15-2007 03:20 PM
Rear sprocket torque 500R Villaven Kawasaki Streetbikes/Sportbikes 1 07-02-2005 01:07 AM
Sprocket Question - 2001 EX500 RadioSilence Kawasaki Streetbikes/Sportbikes 8 06-07-2004 08:20 PM
changing sprocket question? Erique23 The Mechanics Corner 2 05-06-2004 04:57 AM
