Old 05-13-2008   #1 (permalink)
NATE HEAD MIAMI
Default Stock Reed Question
How Do I Tell If My Reeds Are Bad In My Bike They Have Not Been Changed Since I Had The Bike Its Probably The Reason It Does Not Want To Start Any Help On Whatto Do
MIAMI RIDER
NATE HEAD MIAMI is offline   Reply With Quote
Old 05-13-2008   #2 (permalink)
rookrider
have you taken them out to see if there cracked or not
rookrider is offline   Reply With Quote
Old 05-13-2008   #3 (permalink)
RichLockyer
RichLockyer's Avatar
Your bike probably does not start because you fried the ignition module when you welded the flywheel to the crank.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
RichLockyer is online now   Reply With Quote
Old 05-14-2008   #4 (permalink)
NATE HEAD MIAMI
lol yeait tried to crank last night i have to keep kicking like my life depends on it but the reeds are not cracked or anything they look asif there peeling or something is that normal
MIAMI RIDER
Old 05-14-2008   #5 (permalink)
RichLockyer
Not normal, but if they are still sealing it should still start.
Seems like you've got a LOT of issues with that bike, and as much as people are trying to help you on the forum, with so many issues, you could chase problems and replace parts all summer and never get it running.
At this point, I would suggest taking it to a shop where someone who knows what he's doing can fix it right.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 05-14-2008   #6 (permalink)
420longshot
Finally Got Into First Gear
420longshot's Avatar
check and see if it has spark cdi box probable needs replacing
420longshot is offline   Reply With Quote
Old 05-28-2008   #7 (permalink)
NATE HEAD MIAMI
Unhappy
how do i know if the cdi box is bad and my spark plug looks as if its not gettin any smoke on it from the piston its still clean what is that i might just sell the bike an stick to my other bikes its just thats my first big bike dont want to let it go you know
MIAMI RIDER
Old 05-28-2008   #8 (permalink)
RichLockyer
Like I said before...
Take it to someone who knows what they're doing.
You don't, and you have WAY too many things wrong with that bike for ANYONE to try to troubleshoot over the internet.
You can test to see if you're getting spark by removing the spark plug, resting the threaded part on the engine casing, and cranking the engine. If you're getting spark, that's good. Problem is, if you're NOT getting spark, it could be the coil, could be the CDI, could be the stator... there's a half dozen things that could cause the problem.
- Rich
2006 1600 Classic
Member CORVA, BRC
Patriot Guard Rider
Old 05-29-2008   #9 (permalink)
stevied645
Wants better weather!
stevied645's Avatar
+1000000000000000000000000000000000000000000000000
KX250/500 Hybrid LOL Scary Stuff
stevied645 is offline   Reply With Quote
FI2000R question diver165 Kawasaki Cruisers 2 09-24-2006 04:45 AM
Tire pressure on meanie question! wingman01 Kawasaki Cruisers 7 05-14-2006 08:04 AM
stock 2001 Vulcan Nomad FI, sissy bar? craig atkins Kawasaki Cruisers 1 03-19-2006 02:08 PM
stock seat vs mustang seat boredtwodeath Kawasaki Cruisers 10 12-03-2005 08:41 AM
Pilot Power's over stock tires on '05 ZX-6R - Huge Difference! ghost_dog Kawasaki Streetbikes/Sportbikes 21 08-12-2005 12:01 AM
