Old 05-15-2008   #1 (permalink)
jjmancini
Cool Bent Handle Bars on a 1999 KX250
Hey Everyone!
I am new to the forums as well as to off-road riding...
I ABSOLUTELY love it!
But, I did have my first spill today, nothing to bad, but I did end up bending the handle bars a little. How do I go about fixing that?
Any help would be greatly appreciated!
J.J.
jjmancini is offline   Reply With Quote
Old 05-15-2008   #2 (permalink)
Mr mischief
Ideas are dangerous
Mr mischief's Avatar
Exclamation
A metal tube over one end of the handle bar that is bent, a wall and a mate!
As long as there is no crease in the metal before or after – no problem.
To check your results, put some weight on them (you).
DO NOT use the lock-stop on the handlebar movement (knobby thing on the
headstock), that is what the wall and mate are for!!
The lock stop while normally well welded in position is only attached to a
relatively thin section of metal (normally). This holds in place the
steering head bearings, so avoid any undue stress there.
Mr mischief.
Imortal. . .well, will I sink or swim!
Mr mischief is offline   Reply With Quote
Old 05-15-2008   #3 (permalink)
jjmancini
Really... so no unscrewing, just sheer force. Okay, I'll try it!
What is the part that actually bends on a simple spill?
J.J.
Old 05-15-2008   #4 (permalink)
The Menace
Turtle Wax Taster
The Menace's Avatar
Are the bars actually bent, or are they twisted in the forks?
If they are just twisted in the forks, loosen the triple clamps, and just turn the bars until straight. Tighten them back up.
If the bars are actually bent after an easy spill, I would invest in a quality set of handlebars. A cheap replacement set will run you $40, and high quality Pro-Tapers or Renthals about $100. Well worth it in the long run. I prefer oversized Pro-Tapers, but you have to either replace the mounts or the top triple clamp to use them.
I never have trusted bars that have been bent and restraightened. The metal becomes fatigued.
Dennis
2007 V2K Classic LT
Phat risers, Bakup rest, Kawi engine guards, Kuryakyn highway pegs, Kawi rack
The Menace is offline   Reply With Quote
Old 05-15-2008   #5 (permalink)
jdager
buy new handle bars like pro taper or something similar. a lot of them are guarenteed not to bend, and the stock ones will bend the first time you lay your bike over wrong, I did the same thing with mine and switched them out with pro tapers and love them
jdager is offline   Reply With Quote
Old 05-15-2008   #6 (permalink)
jjmancini
Aha! That makes sense. Thanks! I will look into getting some pro-tapers. Unitl then, will it hurt the triple clamp or fatigue the metal by straitening the currently bent handle bars? Or should I just wait and get some new ones?
Thanks so much for the info!
Old 05-15-2008   #7 (permalink)
Mr mischief
Ideas are dangerous
Talking
When straightening handlebars, the idea is not to put to any stress on
any other part of the bike and it is relatively easy to do, just takes some
practice and mechanical savvy!
(that's where your mate comes in!)
The other suggestions are all good, just depends on the depth of your
wallet and, how much serious off-road work you do.
The good and bad point about handlebars that bend is, that they bend!!
That means stress relief - takes some of the shock out of the rest of the
impact to the bike.
The plus for new bars, well, they are shinny - new, and, yes, that is an easy
part of the motorcycle that can be upgraded = better look / more leverage
and less flex.
Also remember that you will have to do some drilling, there are some locating
dowls or pegs that will need to be added to the new handlebars.
Kind of prevents the handlebar controls from twisting around the bars.
Have fun choosing.
Mr mischief.
Old 05-16-2008   #8 (permalink)
chase114
chase114's Avatar
Huh??
Actually, you want your levers to twist in a crash. You want them snug, but not overly tight That way there is some give and they won't break and you are able to hit them back in place and finish the race. There is no drilling involved with replacing bars on an MX bike.
I would recommend Tag Metals.
http://sponsorhouse.loopd.com/Members/cconis/Home.aspx
Wiseco
SixSixOne
Tag Metals
Amsoil
chase114 is offline   Reply With Quote
Old 05-17-2008   #9 (permalink)
jjmancini
Thanks for all the great input!
I was able to straighten them out by putting the front tire against the garage wall and then twisting the handle bars in the opposite direction. It worked out good!
I would like to get some new handlebars soon, so I will take into account all of your suggestions, thanks again!
Handle bar question Jcurtisut Kawasaki Streetbikes/Sportbikes 2 05-13-2006 07:15 AM
Handle bars are out of alignment rabidpanda Kawasaki Streetbikes/Sportbikes 10 06-06-2005 12:25 AM
Knurls for Handle Bars BigRed Kawasaki Cruisers 2 12-18-2004 07:37 AM
Vulcan 1500 Classic Handle Bars dhdaniel Kawasaki Cruisers 1 09-09-2004 11:01 AM
Handle bars on 1600 Classic Curby Kawasaki Cruisers 2 06-14-2004 08:28 PM
