Old 05-15-2008   #1 (permalink)
tractorman38
Default 2007 kx 85 died and won,t start
my son was driving the 07 kx 85 and he said it was like it ran out of gas checked gas good check compression good put new plug in no go still pulled line off tank lots of gas if i hold it full bore and kick it i get and odd puff only 15 hours on it and ideas lots of spark tried 4 plugs
tractorman38 is offline   Reply With Quote
Old 05-16-2008   #2 (permalink)
chase114
chase114's Avatar
Sounds like he stuck the rings, are you sure the compression is good? Pull the exhaust and check out the piston & rings.
http://sponsorhouse.loopd.com/Members/cconis/Home.aspx
Wiseco
SixSixOne
Tag Metals
Amsoil
chase114 is offline   Reply With Quote
Old 05-16-2008   #3 (permalink)
tractorman38
compression was 115 mechanic said should be 120 so looks good
Old 05-16-2008   #4 (permalink)
2stroke173
Bridal Boutique Manager
2stroke173's Avatar
115 is not good compression...i believe the usable range is 120-180 psi! When you checked it did you hold the throttle full open and kick until the indicator will no longer go up?
2stroke173 is offline   Reply With Quote
Old 05-16-2008   #5 (permalink)
jandb917
pre mix for blood
jandb917's Avatar
i would check the compression again then I would look at the flywheel and make sure the nut diddnt loosen off and the flywheel spun on the crank making the timing off ( we seem to be having a rash of that happining latley )
You better watch out ....." IM COMMIN AT YOU LIKE A SPIDER MONKEY "
jandb917 is offline   Reply With Quote
Old 05-16-2008   #6 (permalink)
griffbones
Another old dirt bike guy
griffbones's Avatar
Even 120 is way low! It should start with anything over 100psi, but a good KX85 will have at least 155psi or higher! Most of my little Kawi's have run 160 -170psi
'05 KX85 w/'07 KX100 engine
griffbones is offline   Reply With Quote
Old 05-16-2008   #7 (permalink)
tractorman38
i held it full and kicked it compression was 125 checked spark and it has a nice blue constant spark could it be flooding
Old 05-16-2008   #8 (permalink)
2stroke173
2stroke173's Avatar
I would take this guy's advice Pull the exhaust and check out the piston & rings. You should go ahead and take the reed cage out and look at the piston, cylinder, crank from the intake side too.
Something has gone wrong and you'll need to take the cylinder off and check it out 125 psi isn't good compression...
Old 05-16-2008   #9 (permalink)
tractorman38
yeah but 125 should start the bike
Old 05-16-2008   #10 (permalink)
2stroke173
2stroke173's Avatar
Not if the cylinder's damaged...an 07' with 15 hrs and 125 psi somethings wrong and at this point to me you have no choice but to take the cylinder off to inspect the piston, rings, cylinder, crank. Not trying to start the bike to ride it!
Old 05-16-2008   #11 (permalink)
tractorman38
i will take it and have it check out i will keep you posted
Old 05-23-2008   #12 (permalink)
sesker15
Send a message via Yahoo to sesker15
i am having the same problem. When u find out what it is please let me know!!
sesker15 is offline   Reply With Quote
Old 05-23-2008   #13 (permalink)
420longshot
Finally Got Into First Gear
420longshot's Avatar
i would take the airbox boot off open the throttle up and squirt some fuel in the carb
420longshot is offline   Reply With Quote
Old 05-25-2008   #14 (permalink)
tractorman38
well the top end was screwed i think my son didn't let it warm up enough 700 dollars needed a new cylinder scored thanks to everyone for the help
Old 05-26-2008   #15 (permalink)
stevied645
Can't find time to ride
stevied645's Avatar
can it not be replated???
1996 KX250 - Renthal FatBars - Boyesen Dual Stage Reeds - FMF Fatty Pipe - DEP Silencer - Excel Rims
stevied645 is offline   Reply With Quote
Old 05-26-2008   #16 (permalink)
tractorman38
it could be replated but got a new one at the track for 400 replating was 380 so i went new
Old 05-27-2008   #17 (permalink)
griffbones
griffbones's Avatar
US Chrome charges 179.00 plus shipping and they do really nice work too! Either way, glad to hear that you got it going again.
Won,t Start LARRY BARWICK The Mechanics Corner 5 05-24-2005 05:09 PM
