LinkBack | Thread Tools |
Hey guys,
I just changed my front wheel and tire today and after I got it all back together, I am having problems with my front shocks. when I push down on the front of the bike, the shocks drop down and then stick and dont bounce back, and it sounds like air is leaking out when I push down??? I know the seals are bad and it has been leaking oil, so I dont know if it just ran out of oil and I need to get those seals replaced, or if I didn't get something put back together right? please help thanks, Jim |
#2 (permalink) | |
The original #34
C.Norberg #34 Monster Energy Kawasaki KX250 |
#6 (permalink) |
If the axle threads into the side the rotor is on (Yamaha is this way), all you need to do is loosen the pinch bolts opposite the rotor and compress it a few times.... just lock the front brake and push forward while bouncing down on the bars, or put the tire against a wall. A couple of good stroked should do it.
Tom_E has a good method too, but I'm not sure if it'll work on that bike... Take the fork springs out to let the front suspension bottom out, then tighten the axle while it's bottomed. Works on the big Vulcan cruisers... won't work on a Yamaha.
- Rich 2006 1600 Classic Member CORVA, BRC Patriot Guard Rider |
| 800 front sproket change 17t to 18t | bikeaholic | FAQ'S | 39 | 09-29-2008 07:11 AM |
| Rear wheel change | ThePalm | Kawasaki Streetbikes/Sportbikes | 0 | 04-27-2008 01:38 PM |
| Help Front wheel bearings to tight? | bharris | The Mechanics Corner | 4 | 06-07-2007 08:37 PM |
| VN900 LT Front Wheel Torque... | RC51Pilot | The Mechanics Corner | 3 | 03-13-2007 08:33 PM |
| Front brake problems | placidfemme | The Mechanics Corner | 22 | 05-11-2005 10:07 PM |
