I have a 99 KX 250 and recently purchased a new cilynder and top end kit from Motosport. I bought all OEM stuff. The shop that took the top end off let some dirt get inside the case. What is the best way to get the case clean with out taking it apart? It is not a lot of dirt but I am anal and would like the bike to be as clean as possible before I install the new top end. Also I am installing everything in the next two weeks so any helpfull info would be great. I have a Clymer manual and this weekend I will be preping the bike for the overhaul.
Thanks. |
Wants better weather!
yeah +1 blow it out with a airline as long as it wasnt lots, if it was i would split the cases and clean bearings dirt would act like sandpaper and will cause bearing failure.
KX250/500 Hybrid LOL Scary Stuff
#4 (permalink) |
Its not a lot of dirt. The mechanic stuck a dirty rag around the connecting rod and some dirt was laying in the area around the connecting rod. I have another? How should I clean the studs that come from the case that hold on the cylinder? They have some rust build up from the coolant.
#6 (permalink) |
![]() Join Date: Mar 2005
If it is only minimal ...AND you know that you can see it all..use a peice of fuel line duct taped(reduced down) on the hose of a shop vac. If you think there is some you cant see,...split it apart. Even a "little" dirt,,,agggh....dirt and engines dont mix.
04 MS 1640 Thunder 100 in kit/cams Race ported heads by "dynoray" Thunder air V&H Propipe PC3 |
#10 (permalink) | |
Dazed and Confused
![]() ![]() Join Date: Feb 2008
And will add that for bolt cleaning i use the wire wheel side of my bench grinder.
Riding is good for ones soul. Riding amongst friends is even better. |
| new top end? | Brett250 | Kawasaki Motocross and Offroad | 7 | 05-02-2008 08:59 PM |
| 03 kx125 new top end but loud? | kawirider | Kawasaki Motocross and Offroad | 15 | 03-24-2008 03:37 PM |
| 2000 Kx125 Top End | kawa125 | The Mechanics Corner | 6 | 12-18-2007 05:37 PM |
| Got a 1973 Kawasaki 175, supposedly had a new top end.... | jman47cc | The Mechanics Corner | 0 | 10-04-2004 12:03 PM |
| EL250 - no top end power? | qzak | Main Lobby | 4 | 06-30-2004 10:24 PM |
