Old 06-23-2008   #1 (permalink)
sesker15
Send a message via Yahoo to sesker15
Default Please HELP!!!2002 KX85 Boging bad!! PLEASE HELP
Kx85 is bogging real bad in 1st gear rit before(High RMP) power band, also this happens in 2nd gear
But in the rest of the gears hits power band and pulls nice!
when iam riding the bike a will have it pinned in first gear and it will not move the way it should. acts like it wants to hit the power band but does not.
Does any body know what the problem could be!!!
Please HELP!!!
sesker15 is offline   Reply With Quote
Old 06-23-2008   #2 (permalink)
2stroke173
Bridal Boutique Manager
2stroke173's Avatar
Check to make sure the jets are not clogged and the float level is within specs... you can also check the reeds
2stroke173 is offline   Reply With Quote
Old 06-24-2008   #3 (permalink)
roger the dodge
Please HELP!!!
strange that it does it only in first two gears.you could check that the power valve is ok and shifting properly.if it was carb related ,would it not effect whole range of gears?
roger the dodge is offline   Reply With Quote
Old 06-24-2008   #4 (permalink)
2stroke173
2stroke173's Avatar
The carb and reeds are a good starting point to make sure that fuel delivery is not the problem. On that bike i guess you don't have to take the cylinder off to check the exhaust valves.
I would pull the plug and see if it's black and oily or a tannish brown color that will tell you if the carb tunning is right...
Old 06-26-2008   #5 (permalink)
griffbones
Another old dirt bike guy
griffbones's Avatar
Check the carb and reeds as mentioned, and don't forget about the silencer too, if the silencer is plugged up it will give you problems too!
What is your current jetting and air screw setting?
Did this just start happening?
Did you just buy the bike and found it was running this way?
Bogging is normally a sign of being lean = dirty or plugged up jets, air screw too far open etc...
'05 KX85 w/'07 KX100 engine
griffbones is offline   Reply With Quote
Old 06-27-2008   #6 (permalink)
sesker15
well i just put a new top end in and this started to happen. So What i did was bring the are screw out, because it was all the way in. So with me doing that it fixed the problem. But now the idel on the buke is way to high. How can i fix that? Because the only way to bring the idel down on my bike was the air screw. Thanks for all the help people.
Old 06-27-2008   #7 (permalink)
griffbones
griffbones's Avatar
Bogging, high idle, Sounds lean.
Turning the air screw out should have made a lean condition worse. Are you sure that you don't have an air leak somewhere?
Maybe the bike wasn't bogging maybe it was blubbering (rich). If the air screw was all of the way closed it most definetely would have run rich. Did you try setting the idle speed screw?
Old 06-27-2008   #8 (permalink)
sesker15
the reason i turned the air screw out was my bike was running real rich( a lot of oil on spark plug)and it help the bogging but didnt help the idle. Any suggestions? Thanks for the help griffbones.
Old 06-28-2008   #9 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
Sorry if this insults your inteligence but have you tryed the idle ajustment screw?
Jamie
1996 CR250: 2 engines both with the same 1/2 missing!
After another 125 to kill the garden!
KickassKX125 is offline   Reply With Quote
Old 06-30-2008   #10 (permalink)
winkbynight
Send a message via MSN to winkbynight Send a message via Yahoo to winkbynight
hi guys can any 1 tal me wat the settings are for a kx 80 crab haw meny turns out sud it be thks guys and thks for the help
winkbynight is offline   Reply With Quote
Old 06-30-2008   #11 (permalink)
KickassKX125
It depends on a lot of things that I can't remember! There isn't just a standard setting for all unfortunately.
Jamie
Old 06-30-2008   #12 (permalink)
KickassKX125
I think for my 125 its in the middle groove on the slide and 1/4 turn out on the air screw but it isn't quite right, I dont imagine that it will be much different for you seem as you are in Birmingham but it's a better idea to look at the jetting guide thats at the top of the forum.
Jamie
Old 07-01-2008   #13 (permalink)
winkbynight
ok its just to slow at hitin the power band and i lookd at the spark plug and its black wat duz that ming anyidears guys and thks agin .
Old 07-01-2008   #14 (permalink)
KickassKX125
It means the jetting is off, look at the jetting guide at the top of the forum.
Jamie
Old 07-03-2008   #15 (permalink)
winkbynight
hi guys i had a mate come round and he had a look round the bike and he tuk the carb off give it a good clean and then he set the pin in side the carb and he put it all bk and he sed try that i kicked it first time and it started and tikin over as wal i woz like wow nice 1 and then i tuk it for a go and omg i come back shacking lol it is (very fast for a kx 80 ) so his dun it for him and all i got to give him is a drink and thats guys for helpin (time to get mudey i fink lol )
[txt] Bad Luck anamosity Off Topic 5 03-16-2006 09:42 PM
New-B chick, and already a question! RagDoll_Kunoichi Main Lobby 42 01-22-2006 10:00 PM
Think you are having a bad day? BigJohn Off Topic 23 01-16-2006 09:35 PM
Bad tank of gas minnzoo3 Kawasaki Cruisers 13 09-01-2005 06:37 AM
Ninja 250 runs bad NEED HELP!! IloveCARBS Kawasaki Streetbikes/Sportbikes 5 10-05-2004 04:47 PM
