Old 06-29-2008   #1 (permalink)
driftwood
Default my boys kx85(2003)clutch
when my boy pulls in the clutch an drops it in to first it stalls like the clutch is still out does any body know why this is?
driftwood is offline   Reply With Quote
Old 06-29-2008   #2 (permalink)
paul331
MX. Dad and Racer.
paul331's Avatar
are you letting it warm up before trying to go?
what gear oil you running?
is the clutch adjusted correctly?
have you had the clutch apart?
paul331 is offline   Reply With Quote
Old 06-29-2008   #3 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
Have you tryed revving it as you put it in gear?
Jamie
1996 CR250: 2 engines both with the same 1/2 missing!
After another 125 to kill the garden!
KickassKX125 is offline   Reply With Quote
Old 06-29-2008   #4 (permalink)
condon66
Finally Got Into First Gear
Banging a bike into gear with the engine revving is NOT a good idea. Yes even with the clutch pulled in.
2000 KX 250 Excel hoops, Pro Circuit exhaust, Factory Connection suspension.
condon66 is offline   Reply With Quote
Old 06-30-2008   #5 (permalink)
KickassKX125
If the plates are stuck together the only way to separate them other than taking the clutch to pieces is to just blip the throttle as you put it into gear, if it stalls, it stalls, you don't hold the throttle open and drop it into gear unless it's a speedway bike.
Jamie
Old 06-30-2008   #6 (permalink)
Sledder
Sledder's Avatar
The basket or hub may be notched up a bit which keeps them stuck together a bit. Does the bike creep when you rev it up high while in gear?
Sometimes they do it a bit when you first start it up and it is quite normal.
04 MS 1640
Thunder 100 in kit/cams
Race ported heads by "dynoray"
Thunder air
V&H Propipe
PC3
Sledder is offline   Reply With Quote
Old 06-30-2008   #7 (permalink)
driftwood
Default cheers guys
thanks a lot guys i ajusted the cable and that helped but it is stretched to buggerry so it its a new clutch cable and a servce i think. any suggestion on best gear oil as i dont want to use car oil
Old 06-30-2008   #8 (permalink)
winkbynight
Send a message via MSN to winkbynight Send a message via Yahoo to winkbynight
hi dudes can any 1 help me on this 1 i got a kx 80 and when i rev up it up and let go its slow at bring the revs bk down and when i quckley rev it up it sound like if its going to die i fink it cud be the mixer screw on the carb (wat is the settings for the mixer screw) dus any 1 now thanks.
winkbynight is offline   Reply With Quote
Old 06-30-2008   #9 (permalink)
paul331
MX. Dad and Racer.
paul331's Avatar
--atf type f
--any 10-40 motor oil [non energy conserving]
--gear oil. 80 or 90 wt.
any of these will work fine , its up to you.
why dont you want to use car oil? it will work fine.
Old 07-01-2008   #10 (permalink)
KickassKX125
Never mind car engine oil, I have lorry engine oil in mine, much thicker!!
Jamie
Old 08-02-2008   #11 (permalink)
winkbynight
any 1 on here no a good website ware i can get a Piston Kit for a kx 80 1994 thks dudes
Old 08-02-2008   #12 (permalink)
driftwood
follow this link dont think you will get one cheaper
Kawasaki KX80 KX 80 '88 - '00 Mitaka Piston Kit on eBay, also Exhausts, Performance Tuning, Accessories, Motorcycle Parts Accessories, Cars, Parts Vehicles (end time 10-Aug-08 12:33:32 BST)
Old 08-02-2008   #13 (permalink)
winkbynight
nice 1 mate but mine has 2 rings on the piston ?
Old 08-03-2008   #14 (permalink)
KickassKX125
Most KXs only have one ring, I think im right in saying that the trail bikes like the KDXs have 2 rings (correct me if im wrong; KDXGarage or someone who knows them inside out)
Jamie
Old 08-04-2008   #15 (permalink)
winkbynight
yea thats wot i fort befor i opened it up but na its 2 rings do you no wat size i need our haw i cud tal thks dudes
Old 08-05-2008   #16 (permalink)
greenblur80
engine tech
some companies sell pistons with one ring for better acceleration,top end power,more overrev,less cyl bore wear.but u lose a little bottom end power from increased blow by past the piston.wiseco usually sells them for a few different models.i didn't see one for ur bike on there website.they got 1 for 01-08 kx85,00-08 kx60 & they have 1 for my 97 kx250 or any 92-01 kx250.these bikes come with 2 rings from the factory.so u can use a 1 ringer in ur bike.as for your bike being slow to idle down u could have a air leak u should check the intake boot to carb clamp is tight,check that the intake is not dry rotted & leaking,check that the intake bolts are tight carefull tho cause there only need to be tightened to 7-8ftlbs,then u can try the mixture screw but i dout thats your problem but try it before the next step.the mixture screw setting can be any where from 1 to 2 1/2 turns out from fully seated depending on how rich or lean ur pilot jet is normally it's should be 1-1/2 to 2 turns out from fully seated.if not in the 1-1/2 to 2 range u should go up or down in size with the pilot jet.set the mixture screw at 1-1/2 out if that don't help u either need to clean the carb or replace the intake gasket(s) cause ur running lean for some reason
Last edited by greenblur80 : 08-05-2008 at 04:19 AM. Reason: accidentally posted before i finished
greenblur80 is offline   Reply With Quote
Old 08-06-2008   #17 (permalink)
winkbynight
yh mate i will try that thks alot for your time and nice 1 for your help mate
Old 08-17-2008   #18 (permalink)
winkbynight
hi all any 1 on here now ware i can get a bore from for a kx 80 1994 thks guys
Old 08-18-2008   #19 (permalink)
renegadejim
it sounds like the problem with ur clutch is the basket. my kx125 did the same thing and i took the clutch out and its notched real bad. banging into gear in my opinion made it even worse cause thats what the previous owner told me to do. look into a new clutch basket. they are expensive but that is probably what is wrong.
renegadejim is offline   Reply With Quote
Tale of Six Boys BigJohn Off Topic 4 11-09-2006 01:40 PM
25th Annual Oyster Run- Sept 24, 2006 - Calling out the PNW Boys Spok Rides, Events and Rallies! 79 09-26-2006 11:55 PM
Raising Boys BigJohn Off Topic 23 06-22-2006 03:04 PM
The Joys of having boys!!!!!! 1400pilot Off Topic 31 11-29-2005 09:24 AM
Took the boys to Bike Night ridenagain Kawasaki Cruisers 7 07-21-2005 11:15 AM
