Old 07-05-2008   #21 (permalink)
stevied645
Wants better weather!
stevied645's Avatar
try removing the side cover and cleaning up the contacts on the magneto etc
KX250/500 Hybrid LOL Scary Stuff
stevied645 is offline   Reply With Quote
Old 07-05-2008   #22 (permalink)
roger the dodge
Hi, I HAD THE SAME PROBLEM WITH MY SONS KX85, you Could Start At The Coil And Check It With An Ohm Meter.you Will Need Repair Manual Cos This Will Have Test Procedure And Correct Ohmage Readings.if Ok Then Move To Stator,again Refer To Manual For Procedure.by Far The Best Way To Sort Electrical Problems Is To Replace With A Part You Know Is O.k But This Is Not Always Possible Unless You Have Someone With Same Bike That Doesnt Mind You Trying! I Ended Up Fitting New Stator Plate. I Wish You Luck,electrical Problems Suck!
roger the dodge is offline   Reply With Quote
Old 07-07-2008   #23 (permalink)
c_mcsherry
Yes electrical problems do suck. I do have the factory manaul. Just got it. I wil check the coil & stator. I don't think I can check the cdi as I dont' have the special tool required. And I don't have known good parts to try. I will get reading & get back.
c_mcsherry is offline   Reply With Quote
Old 07-07-2008   #24 (permalink)
stevied645
stevied645's Avatar
i have a stator, coil, wiring and cdi unit from a 1990 kx250. i dont know if they will do a 1991 u will have to find out, but if they do and you need any of those parts pm me, i was supposed to be selling them to someone on here from america and postage was going to be about $30 for the lot, let me know.
Old 07-07-2008   #25 (permalink)
roger the dodge
yeh,cdi is possibility but rare,also fly wheel can lose magnetism but again rare i think.
Old 07-07-2008   #26 (permalink)
c_mcsherry
Does anyone know if changing the entire electrical system(flywheel, stator, cdi, coil) from my 1991 with one from say a 1992, 93, 94 etc. will work? And if so are there any modifications needed? Has anyone done this succesfully? Thanks again.
Old 07-08-2008   #27 (permalink)
dmstarr
Tree Magnet
dmstarr's Avatar
Please tell me you've checked the connections. Especially the boot.
dmstarr is offline   Reply With Quote
Old 07-08-2008   #28 (permalink)
c_mcsherry
Connections have been thoroughly checked. However I will check again.
Old 07-10-2008   #29 (permalink)
c_mcsherry
I've been working crazy hours and I have military drill this weekend. I will get the electrical system readings and post as soon as I can.
Old 07-28-2008   #30 (permalink)
seanc331
Any luck?? I have an 86 KX 125 with the same problem....
seanc331 is offline   Reply With Quote
Old 08-03-2008   #31 (permalink)
reload
Try Cleaning The Carb. Remove It . Disasemble Jets, Make Sure You Can See Thru Them. I Find When Mine Get Dirty I Have A Hard Time Starting Any Bike. It's Usually 1 Grain Of Sand In The Little Jet That Has The Tube With All The Little Holes In It. Found That To Be The Case On Hondas, Yamahas Too. Good Luck
reload is offline   Reply With Quote
Old 08-07-2008   #32 (permalink)
greenblur80
engine tech
mcsherry were in nj u live.i live in toms river so if u ever need i can stop by & look at your bike for ya.i usually go riding in manchester,berkley,whiting or forked river but it's getting hard to go riding in the trails in nj because the cops like to bust ur balls especially within the last 8 months after someone i knew got killed on a quad off lacy rd they been cracking down on "illegal" riding.
greenblur80 is offline   Reply With Quote
Old 08-08-2008   #33 (permalink)
MoToMaStR
The Welder
MoToMaStR's Avatar
Send a message via AIM to MoToMaStR
Go out to monmouth county dude. hit farmingdale and howell township. I use to live in lakewood/howell border right on squankum road. I was a little kid, terrorizing my neighborhood on my yz125 10 years ago. freewood acres has good riding too. in lakewood, theres the ledgandary kawasaki trails, its out past the railroad tracks in the wood across from joda and apollo. next to JCP&L building. haha. if you want to know some more sweet spots to ride in central jersey, hit me up bro. laterZ
Went to the playground!
Where all the kiddies play!
Pulled out my 240!
AND I BEGAN TO SPRAY!
MoToMaStR is offline   Reply With Quote
Old 08-11-2008   #34 (permalink)
c_mcsherry
Thanks to all who posted. I have not solved the problem yet. However I ihave not even had the chance to even try & start it. Just too busy. I will keep you posted when I can.
Green blur. I live in Manchester and my I work in Toms River sort of. I start my day there then head up north. I have been working crazy long hours between civilian & military jobs. It would really be cool if you could come take a look.
As far as the cops I know what you mean. I used to ride at Asarco. But have heard the cop stories as of late. I heard about that person you know that got killed. Sorry about that. Get back to me and may be we can set something up. My name is Chris the way
Old 08-11-2008   #35 (permalink)
josh l.93
try your cdi unit.. i had a mega electrical problem once.. turned out my cdi was caked in mud and water.. i jus sprayed some wd40 on there and waited it out..
by the way it did exactly the same as urs..
josh l.93 is offline   Reply With Quote
Old 08-11-2008   #36 (permalink)
josh l.93
i also live in manchester
Start with the basics, the battery is the life blood. tttjump What I learned today 4 03-16-2008 02:48 PM
Hard "re-starting" after 6 miles billtuti The Mechanics Corner 9 02-05-2008 09:09 PM
Vulcan 1500 Hard Start g-rod72 The Mechanics Corner 3 01-22-2008 07:59 AM
Bike is getting tougher to start Bociba Kawasaki Streetbikes/Sportbikes 7 02-25-2007 11:33 AM
1999 klr 250 hard start hoover Kawasaki Motocross and Offroad 6 12-28-2006 11:06 AM
