Old 07-07-2008   #1 (permalink)
kwikaz
kwikaz's Avatar
Default cylinder centering pins
Hi all who,s farmiliar with the cylinder centering pins on a kx125 1999 model ?? im doing a top end rebuild and i need to replace the centering pins but i dont know the best way to take out the old ones , i tried removing them with a pair of pliers but no luck so i thought someone around here could give me a heads up on the matter??? thanks all
kwikaz is offline   Reply With Quote
Old 07-07-2008   #2 (permalink)
stevied645
Wants better weather!
stevied645's Avatar
are u talking about the 2 dowel type things.
KX250/500 Hybrid LOL Scary Stuff
stevied645 is offline   Reply With Quote
Old 07-17-2008   #3 (permalink)
kwikaz
kwikaz's Avatar
Default yes
yes mine are in bad nik?? need to replace..
Old 07-17-2008   #4 (permalink)
FPMXer
2Stroke 4 life!!
FPMXer's Avatar
They should pull out with plier's but if not then give them a little heat.
86' 250R Trike
88' LT500RJ Quadzilla
My blood is yellow and red!
FPMXer is offline   Reply With Quote
1995 EN500 Cylinder Gasket - Replace? climb_eng The Mechanics Corner 3 02-07-2008 07:08 PM
cylinder help nalwor Kawasaki Motocross and Offroad 5 11-22-2007 10:07 AM
Piston install/break in/jetting info HERE! >>> Lakeshore Kawasaki Motocross and Offroad 0 09-15-2006 01:05 PM
Mule 2500 Air in Brake/Master Cylinder Bugman Kawasaki ATV and Mule 2 10-18-2005 04:12 PM
Trouble with one cylinder druk The Mechanics Corner 8 01-11-2004 08:02 PM
