Old 07-30-2008   #1 (permalink)
buckwheat_la
Default in need of major help with 1984 kdx 200
so i have a 1984 kdx, that has a dead spot in the midrange exceleration. It has had this problem since day one, I have rebuilt the top end, rebuilt the carb, redid the exhaust, new reeds, new airfilter, and after all of this, i still have a spot in the midrange that it doesn't run properly at. Does anyone have any ideas for this. I have been told at this point that it may be that the cylinder is worn (not likely but am grasping at this point). I could really use some advise for this.
buckwheat_la is offline   Reply With Quote
Old 07-30-2008   #2 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
Did you rejett the carb and put the clip where it needs to be etc?
Or just rebuild it.
Also its old, so parts caould be warn in the carb.
So what did you replace in the carb?
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Old 07-31-2008   #3 (permalink)
buckwheat_la
i had the carb rebuilt at a local shop, they assured me that it was cleaned up, a jet replaced etc. So when it didn't work, i borrowed my friends carb also off a 84 kawasaki 200 kdx (which runs perfect) and tried it and it still ran really poorly with the same lag, but thanks for the imput but i am pretty sure that the carb (s) are ok.
Old 07-31-2008   #4 (permalink)
Billy B
Billy B's Avatar
Just a shot in the dark but is the kips valve operating correctly?
Kdx200-RBdesigns modified head and carb KX250 fork swap FMF torque pipe FMF turbine core2 VF3 reeds
Billy B is offline   Reply With Quote
84 kdx 200 help buckwheat_la Kawasaki Motocross and Offroad 2 07-25-2008 08:28 AM
1988 Kdx 200 abbadonsrevenge Vintage Motorcyle Info 2 01-09-2008 06:14 PM
1984 Kdx 200 Ben1 Kawasaki Motocross and Offroad 11 11-07-2007 07:26 AM
89 KDX 200 I'm looking for replacement carb info. MXHowes Kawasaki Motocross and Offroad 1 08-24-2007 10:44 AM
KDX 200 (1984) start problem thomasdepaepe The Mechanics Corner 13 06-29-2007 08:55 AM
