Old 07-31-2008   #1 (permalink)
tmartz
Default Kx100 powerband trouble
I have a 2004 kx100, with fmf fatty pipe and silencer. Lately ive been haveing a problem. The bike will start up fine but when i go to ride the bike at high revs all the time the bike will bogg real bad and ill have to hold the throttle till it catches. It use to do it but just not really bad it was more of a aggervating thing then how it is now where i could barley ride in the pits or anywheres i just wouldnt be able to take the frustration. Please help
tmartz is offline   Reply With Quote
Old 07-31-2008   #2 (permalink)
Sledder
Sledder's Avatar
Kind of the nature of the beast,it is a kx,it is a moto-x bike and that is somewhat how they are...but there are a few things that can often really improve the situation. Most often ,there is a HUGE difference between being jetted "perfect" vs." almost perfect"...the way to perfect jetting is done by actual testing only...read the jetting guide .
Also some aftermarket pipes can offer you more bottom end if that is what suits your riding...look for words in the piupe description like "gnarly" or "grunt" ...look at fmf or PC sites and do some reading.
Also V-force reeds,although expensive seem to always work well on small mot-x bikes to improve low end response.
Finally,some light engine work from one of the motocross engine ppeople will help,as a bit of compression increase(requiring you to use high test 92 gas) will help bottom end a lot.
Start with perfect jetting.
04 MS 1640
Thunder 100 in kit/cams
Race ported heads by "dynoray"
Thunder air
V&H Propipe
PC3
Sledder is offline   Reply With Quote
Old 07-31-2008   #3 (permalink)
tmartz
Yeah i have a fmf fatty pipe with silencer i really dont have the extra money for reads im a little younger. But i have also messed with the screw that like goes into the carb thingking it was the idle screw i dont know if that could have made a difference. I was thinking about rejetting it maybe someone has specs for the same bike with the tempurture around 85 degrees. Keep the help coming i appreciate it.
Thanks
Old 08-02-2008   #4 (permalink)
tmartz
its almost as if its gasping for air ive played with the idle screw and other screw thats like almost right under the idle screw i dont know what it is but i dont know if it messed something up
Old 08-02-2008   #5 (permalink)
stuart1981
Finally Got Into First Gear
that would be the air screw, pretty sure on that bike its, fully screw in not totally tight, just so it seats nicely, then 1 and a half to 2 turns out!
stuart1981 is offline   Reply With Quote
Old 08-02-2008   #6 (permalink)
tmartz
thanks im going to do that right now and then test it out tommorow
Old 08-03-2008   #7 (permalink)
tmartz
i tested it out today and there was a difference but the bog is still ther threw all gears just havent go it to 6th gear but im sure it will do it if it does it right up to 5th "only at high revs"
Anyhelp?
KX100 Jetting Survey griffbones Kawasaki Motocross and Offroad 17 05-08-2008 12:41 PM
KX100 frame dmstarr Kawasaki Motocross and Offroad 1 10-17-2007 04:30 PM
KX100 Idle help griffbones Kawasaki Motocross and Offroad 5 12-27-2006 05:10 PM
thinking of getting a kx100 corvettesR1 Kawasaki Motocross and Offroad 3 11-02-2006 08:03 PM
03 KX100 Questions...? juz250 Kawasaki Motocross and Offroad 3 05-18-2006 09:35 PM
