Old 08-06-2008   #1 (permalink)
saki83
Default KX80 Clutch Springs
All, I've been visiting the site for a little bit and just joined as I am in the final stages of finishing a total rebuild on a 1983 kx80. One quick question. How tight should the bolts be that hold the clutch springs in the basket? I thought at first they were supposed to be tightned all the way but then realized that there was no travel between the plate on top of the springs and the throwout bearing. The result was the clutch being fully engaged. Is there a torque spec or am I supposed to unscrew a certain distance? Thanks will post pics later.
saki83 is offline   Reply With Quote
Old 08-07-2008   #2 (permalink)
chase114
chase114's Avatar
There is a torque spec, but I don't know what it is. They are supposed to be tight, I'm sure the manuel will tell you the spec.
http://sponsorhouse.loopd.com/Members/cconis/Home.aspx
Wiseco
SixSixOne
Tag Metals
Amsoil
chase114 is offline   Reply With Quote
Old 08-07-2008   #3 (permalink)
saki83
Thanks, but no manual. I re-read my first post and would like to clarify, When I tightened the plate that holds the springs in all the way until it bottomed out; the clutch was engaged. by engaged I mean it was locking all the bits of the engine together. Which is cool right? I guess what I'm struggling to understand is how the throwout bearing is supposed to release the pressure on the plates. I've replaced the clutch on my car before, but this is a little bit of a different setup
Old 08-07-2008   #4 (permalink)
chase114
chase114's Avatar
Yeah, that is the way it is supposed to be.
Wiseco
SixSixOne
Tag Metals
Amsoil
Old 08-08-2008   #5 (permalink)
Billy B
Billy B's Avatar
I just redid a 93 kx 80 for my nephew and if i'm correct it's 78 inch lbs for the clutch spring bolts. Matter of fact looking at my kdx200 manual and it's the same. I will check the kx80 manual in the morning but i'm pretty sure that is it. Run them down even so you get an accurate read on them.
Kdx200-RBdesigns modified head and carb KX250 fork swap FMF torque pipe FMF turbine core2 VF3 reeds
Billy B is offline   Reply With Quote
kz 400 starter on a kz 440? Alibi Vintage Motorcyle Info 8 09-30-2008 09:27 AM
Clutch Handle Won't Disengage (lots of pics here) hanilrez Vintage Motorcyle Info 13 05-10-2008 02:41 PM
1997 kawasaki kx80 clutch problems HELP me kawasaki813 The Mechanics Corner 3 03-21-2008 06:39 PM
Sticky Clutch KX80 Paul1965 Kawasaki Motocross and Offroad 3 06-14-2006 12:07 AM
1985 KX80 - Clutch Problem xEnDoNx The Mechanics Corner 3 06-12-2006 07:11 PM
