Old 08-12-2008   #1 (permalink)
minichopper
Default KX 125 engine
Hey we bought a kx 125 and cant figure out the engine year model i know the frame is 1987 so I ordered a piston for a 1987 but it is to long and hits the crank so can anyone tell how to ID the year of the engine Thanks
minichopper is offline   Reply With Quote
Old 08-13-2008   #2 (permalink)
mainthang
mainthang
Send a message via Yahoo to mainthang
i recently bought what i think is an 86 kx125.How or where do find the vin or how do i find out what year it is?
mainthang is offline   Reply With Quote
Old 08-13-2008   #3 (permalink)
Fatcat 1
Finally Got Into First Gear
Here fellas follow this link and your questions should be answered!
KDXGarage - VIN Information
Fatcat 1 is offline   Reply With Quote
Old 08-13-2008   #4 (permalink)
mainthang
mainthang
where at on the bike is it?
Old 08-13-2008   #5 (permalink)
minichopper
will this also work for engine ID
I assume the engine has numbers on it to
Thanks
Old 08-13-2008   #6 (permalink)
Fatcat 1
Your vin number should be on the neck of the frame where the forks connect on the side in a vertical position. The engine should match the year on the VIN unless someone has completely removed and swapped engines!
Old 08-13-2008   #7 (permalink)
minichopper
I kinda think the engine has been swapped
Old 08-13-2008   #8 (permalink)
Fatcat 1
A more well versed person here will have to help you on that I am not sure if you can ID with casting numbers on an engine??
Old 08-14-2008   #9 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
For the engine number, look close to where the kickstarter goes into the engine. It will be on the top of the engine. Post the numbers.
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 08-14-2008   #10 (permalink)
mainthang
mainthang
found it guys thanx! Its an 86.So now where do i find an impellar.Question #2 Where can i find an impellar shaft for this year? The local shop here in town says the discontinued it! I've tried to order it from bikebandits and they say they said they cant find it and would refund my money in 20 business days if they cant find it! Do i have any other options besides ebay where i can't find it either.I am trying to replace a waterpump seal and that impellar because i was told i had water in my oil.
Old 08-14-2008   #11 (permalink)
KDXGarage
KDXGarage's Avatar
Look on eBay for a used one. You may even stumble across a new one. I am always constantly searching on there for parts for my old bike (ok, bikes).
Old 08-17-2008   #12 (permalink)
minichopper
hey
I have looked all over the engine and these are the only numbers I can find
DE18805
KHlKX125
I know the frame is a 1987 but I dont think the engine is
Old 10-05-2008   #13 (permalink)
trashedKX125
I have a 81 KX with a replacement block anyone know what year it is block # is KX125AE010673
trashedKX125 is offline   Reply With Quote
KDX 200 Engine in a KX 125 Frame knickk Kawasaki Motocross and Offroad 7 08-26-2007 05:42 AM
KX 80 engine into a 125 frame and some Q's traskrider Kawasaki Motocross and Offroad 3 04-03-2007 09:38 AM
92 KX 125 Engine Need Aphraidknot The Mechanics Corner 0 03-25-2007 04:41 PM
To Engine Brake Or Not To Engine Brake, That Is The Question... TMac Kawasaki Cruisers 8 04-20-2005 07:37 AM
engine noise Tyler 900 The Mechanics Corner 7 04-17-2005 02:06 AM
