Old 08-13-2008   #1 (permalink)
renegadejim
Exclamation '93 kx 125 clutch problem
hey everyone. i just bought a 93 kx125. the bike runs great but i am having some clutch problems. i took the clutch cover off and noticed the basket has tons of notches in it. i was wondering if anyone has any tips for installing a new basket and clutch plates. any help would be greatly appreciated. also what would be the easiest way to remove the clutch nut? everytime i try to loosen it the engine turns.
renegadejim is offline   Reply With Quote
Old 08-14-2008   #2 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
Look on the Motion Pro site for the clutch holding tool. If the notches are light, you may be able to file them down once, but it is a band-aid solution. A new basket, though costly, is a better solution.
If you don't already have a manual, I recently saw one on eBay for $5.
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 08-15-2008   #3 (permalink)
renegadejim
the notches are real bad ill try to get some pics up if i can. the basket definitly needs to be replaced. i dont wanna risk messing anything else up. it would be real expensive if the tranny or something went. so fixing the clutch is the route i wanna go. also i was wondering would something like an impact wrench work for taking the nut on and off? also this is off topic but i have a new seal for the water pump shaft like under the impeller. how do i get that nut off? the engine turns when i turn that. would an impact wrench work for this too cause i am considering buying one but i wanna hear what ppl have to say first.
clutch problem 2006 Vulcan 500 saulvb The Mechanics Corner 18 12-01-2007 07:58 PM
V2K Clutch problem update. LordGT Kawasaki Cruisers 5 05-28-2007 01:10 AM
kx 125 clutch sticking scottmercer Kawasaki Motocross and Offroad 0 06-14-2006 06:38 PM
1985 KX80 - Clutch Problem xEnDoNx The Mechanics Corner 3 06-12-2006 07:11 PM
Hey hey, I am noticing a lot of new Pac. Northwesters around here. trikebubble Off Topic 33 09-23-2005 05:47 PM
