Old 08-19-2008   #1 (permalink)
melissasbike
Default 1986 kdx200 ignition timing
Hi there,i have aquired a 1986 kdx200 aircooled model,bought as a nonrunner,i have fitted-a new sator,a new coil,a new sparkplug,a good cdi unit and fitted new piston rings ,it sparks ok and compression is good,fuel is present(wets plug after a bit)bike still doesnt want to start? took air filter out give it a good kick(on kick start)TEMPTATION! engine backfired down exhaust? checked timing marks and are lined up as in manual,does anybody have correct timing details or any ideas?MANY THANKS!:
melissasbike is offline   Reply With Quote
Old 08-19-2008   #2 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
Congratulations on getting an '86 KDX200. I have a 1987 KDX200.
Do you see three marks at about 10 o'clock behind the stator? There is a raised line on the stator I beleieve (or maybe an open slot). It is supposed to be lined up with the center mark.
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 09-07-2008   #3 (permalink)
MIKEY14703
the timeing should be set at 22 degrees before top dead center
MIKEY14703 is offline   Reply With Quote
kdx200 timing runt The Mechanics Corner 0 11-04-2007 04:59 PM
KX85/100 ignition timing dmstarr Kawasaki Motocross and Offroad 3 10-17-2007 04:20 PM
1986 Ninja 600 ignition schematic question... thebsproject The Mechanics Corner 0 07-09-2007 11:44 PM
1986 Ninja 600 ignition schematic question... thebsproject Main Lobby 0 07-09-2007 07:27 PM
Ignition Timing and Pulsing Coil theory itjstagame The Mechanics Corner 3 09-28-2006 09:28 AM
