LinkBack | Thread Tools |
I have a 99 KX250 with a 18" rear wheel and a 120/100/18 Maxxis IT tire. I do a lot of woods ridding and ocasionally hit the track. The woods ridding is mostly single track black diamond stuff and the track that I ride is really tight and I never get out of 3rd gear. I need to replace the front and rear sprocket as well as the chain and was hoping some one could help me with my selection. I am currently running a 12 tooth primary and a 49 tooth rear. I feel that I need a little more torque.
Kx250 has never really been known for torqe because of the purpose it was designed for. the power valve setup, exhaust design, flywheel weight & gear ratio's are all kilowatt based and not torque. but still i would stay with the 12 49 setup. gear down and rev it like only a kx can if you drop a tooth on the front sprocket the ratio change is quite dramatic (relative) Were if you maybe increase on the rear about 2 tooth it might be better. just remember if you increase your ratio (smaller front or lager rear) your gear ratios might be off and the result can be changing gears like crazy just to get up to 60mph good luck! at the end of the day its only trial & error to personal preferance
Maybe go up to a 51 rear it will give ya some more pull off the bottom but also if most of your riding is trails i would think about a flywheel weight.
Kdx200-RBdesigns modified head and carb KX250 fork swap FMF torque pipe FMF turbine core2 VF3 reeds |
#5 (permalink) |
On my 01 KX250 I dropped my primary to a 12T and it still didn't get what I needed either... I think BillyB is right by going with a flywheel weight. I've had a Steahly 11oz on for a few weeks, and it made all the difference. You can lug it like a 4strk, but makes the transition into the powerband much smoother and gives much more control when on the pipe, letting you run the motor the way it was designed. Best $100 I've spent on this bike yet.
| Stock sprocket size for 1986 Ninja 900? | landmissle | Vintage Motorcyle Info | 2 | 05-10-2008 10:05 AM |
| KX250 what Sprocket Size | Ka0sX | Kawasaki Motocross and Offroad | 9 | 03-16-2008 11:57 PM |
| Sprocket size? | 2stroke173 | Kawasaki Motocross and Offroad | 15 | 11-05-2007 07:50 PM |
| KX65 Front Sprocket/Rear Sprocket Size | sd_outkast | Kawasaki Motocross and Offroad | 2 | 11-09-2005 02:55 PM |
| Stock sprocket size? | theshark | Kawasaki Motocross and Offroad | 3 | 09-26-2005 09:42 AM |
