Old 09-01-2008   #1 (permalink)
litning
Kawwy Green Blood
Question kx80 clutch problem maybe??
I've never shifted a dirtbike before but....when I sqeeze in the clutch...I have to wait a good second before I can get the next gear...instead of like speed shifting which I've done on all sort of street bikes....I have replace fluid which was old...used Belray gearsaver 85w. So is the clutch going or a particular part. Thanks
litning is offline   Reply With Quote
Old 09-25-2008   #2 (permalink)
litning
Kawwy Green Blood
Thumbs up KX80 Clutch problem resolved
It's been a bit since I wrote this, but finally fixed it....replaced the cable, and the clutch plates, springs, etc. And went ahead and replaced the seals for water pump, oil and clutch actuator...also replaced the actuator itself...very worn and the pusher and washer along with bearing for water pump and the pusher bearing....On my 94' you have to remove the nut to get the clutch assy. out....no way around...Let me tell ya , wasn't easy...used a breaker bar, impact, nope...heated it ( not glowing red, just a little hot) and some real good penetrating oil.....I have found it'll suck right into the threads, you spray it on when it's hot, let it cool try it again, and then the impact and you got it....To say the least the clutch disc plates were very gummy and worn.
NOW she shifts just fine...no hesitation....Talk to Bel-ray and they recommended 75w for the kx80. Went ahead and got some, no problem.
Thanks for everyone that responded.
zxr750h2 clutch problem jaypo The Mechanics Corner 1 03-26-2008 05:29 AM
wierd noise on bike clutch problem? ninjaguy1288 Kawasaki Streetbikes/Sportbikes 1 10-19-2007 05:35 PM
KDX 200 Clutch Problem Kaleel Kawasaki Motocross and Offroad 3 04-29-2007 11:32 AM
Clutch Sticking problem jerry chabino The Mechanics Corner 3 09-14-2006 06:20 PM
Hey hey, I am noticing a lot of new Pac. Northwesters around here. trikebubble Off Topic 33 09-23-2005 05:47 PM
