Old 09-22-2008   #1 (permalink)
mechie101
Default no power band 1 + 2 gear
i just bought a kx 80 1991 model it doesnt hit 1 and 2nd gear power valve but the rest are fine it just gets to like just before the band and just seems to rev and no band can some 1 help me
mechie101 is offline   Reply With Quote
Old 09-22-2008   #2 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
UMMMM you lost me....I will be glad to help if you can clarify what you mean.
Are you saying it does not like to rev up very far in the first two gears?
Its easier to pul the lower gears, than the taller ones, so just missing your problem i think.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Old 09-22-2008   #3 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
I think what he is saying is that he hasn't much power in 1st and 2nd gear, if i'm right and thats what he is saying then here is my answer to him:
Its a small 2 stroke, all small 2 strokes have very "close" powerbands in the bottom 2/3 gears and wont go very fast as those gears are for getting moving not for going fast/cruising.
Even on medium sized 2 strokes like 125s and 200s you will not have much power in 1st/2nd.
I myself have not ridden a 500 but I imagine to some extent that they are the same.
Jamie
1996 CR250: 2 engines both with the same 1/2 missing!
After another 125 to kill the garden!
KickassKX125 is offline   Reply With Quote
Old 09-22-2008   #4 (permalink)
mechie101
mate ive got a kx 85 race tuned and theres a decent band in that what im saying is its almost like theres none (STUTTERS)
Old 09-22-2008   #5 (permalink)
jay08
Foil Inspector
Yea you can compare it to the tuned 85. The three things i look at first when i get one that bogs or has no power is. The power valve it may be completely gunked up or came way out of adjustment and it's not breathing right. Also the reed valve on the carb side they just wear out. but i dont think i would be that drastic more like loss in hp. And lastly is a toasted ring. Everything is still spinning but maybe you lost compreesion and not getting the bang for you buck. Another thing that i have seen is sometimes the case will leak and suck air and you can get all kinds of wacky stuff going on. If you can hold a smooth constant idle your case is most likey sealed. Things i would do check the power valve should be closed at idle or reall close to closed and check the reed valve were the carb connects they break down and become sloppy and could crumble if given enough time.
jay08 is offline   Reply With Quote
Old 09-24-2008   #6 (permalink)
KickassKX125
At least someone has some common sense.
Get this bike race tuned, THEN compare them. And bear in mind, this bike is a 80, not an 85.
Jamie
Old 09-25-2008   #7 (permalink)
litning
Kawwy Green Blood
I have a 94-kx80 and if I let it hit powerband in second gear and hold it. Up comes that front wheel and it don't stop until I let off. I weigh 175 lbs??
I would chk compression first...maybe time for a topend.
litning is offline   Reply With Quote
07 & 08 Z1000 Gear Shift "How To"... eidian Kawasaki Streetbikes/Sportbikes 10 04-03-2008 11:22 AM
Mule gear grinding/won't go into gear HeatherDog Kawasaki ATV and Mule 2 03-13-2008 09:55 AM
The Lessons Of Leather Track Gear Slo'Poke Main Lobby 21 09-12-2007 08:30 AM
81 KM100a 1st Gear Skipping aaron_gx Kawasaki Motocross and Offroad 1 05-07-2007 04:20 PM
94 vulcan 750 no second gear larrycavan The Mechanics Corner 6 02-05-2006 09:21 AM
