Old 09-24-2008   #1 (permalink)
adam.peat74
Default Dripping Goo
I've a treasured KMX125 b10, 8yrs old now with 20k on the clock.
in the last few weeks i'm getting a lot of oil coming form the exhaust and i think more smoke than usual (although its always pretty somkey )
Possibly feeling lower power in low revs also although once going she's alright.
I've checked the oil pump adjustment and that is as it should be.
the bike has a big one expansion, and a production silencer (used to be DEP but too noisey for where i'm riding)
what else is worth looking at?
thanks.
adam.peat74 is offline   Reply With Quote
Old 09-24-2008   #2 (permalink)
Ericthejet
Forensic Bug Splatter Analyst
Ericthejet's Avatar
Check your sparkplug.
1984 Ninja 900 (A1)
To make it go faster I need to add more lightness!
Ericthejet is offline   Reply With Quote
Old 09-26-2008   #3 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
Check the compression, has the engine ever been rebuilt?, 20k is a fair bit even for these road engines! Sounds like the rings are in need of renewal or even better, a full rebuild then if you use high quality parts it won't want doing for another 20k.
Jamie
1996 CR250: 2 engines both with the same 1/2 missing!
After another 125 to kill the garden!
KickassKX125 is offline   Reply With Quote
Old 09-26-2008   #4 (permalink)
KickassKX125
Just read my manual, the service period for the 125s top end is every 17500 miles and a full rebuild at 30000 miles.
Jamie
Old 09-27-2008   #5 (permalink)
adam.peat74
the plug is a bit sooty but not oily, was replaced approx 3k ago.
Thick, white gunk dripping from KX250 sehret2010 Kawasaki Motocross and Offroad 20 06-09-2008 06:34 PM
gas dripping from exhaust jcmcc The Mechanics Corner 2 09-12-2007 05:17 PM
KX coolant dripping zhilmi Kawasaki Motocross and Offroad 7 08-18-2007 10:39 PM
Oil dripping out of overflow tube Ryan F Kawasaki Cruisers 4 06-25-2007 11:13 PM
Fuel Dripping out overflow tchandlervn500 The Mechanics Corner 4 09-25-2005 12:17 AM
