Old 09-25-2008   #1 (permalink)
firemat
firemat's Avatar
Default transmission stuck in 4th or 5th gear
I was riding tonight on my lil 1984 kdx80,and when I came to a stop and take off again...the transmission didn't want to downshift..so I had to figure out a way to drive home in 4th or 5th,...think 4th..but thats not the important part....I am wondering if anyone knows what I should do...I'm thinking its probly something with the shifter linkage..but I have never taken anything like this apart..thanks for the help guys
Mathieu
firemat is offline   Reply With Quote
Old 09-27-2008   #2 (permalink)
firemat
firemat's Avatar
I took the engine out of the frame...its in my truck...now I am going to start pulling it apart...starting with the head and stuff to pull apart the crankcase halves...now to get to the shifter drum and linkage..what side is that easiest to get to...cause I don't really wanna get right into the gears and stuff of the tranny...cause I know nothing about that
Mathieu
Old 09-28-2008   #3 (permalink)
gaz
Turtle Wax Taster
Not sure about the location on a kdx but on an '02 125 kx I had the shift lever move down a bit (splines started to strip) and was hitting the frame which stopped it from down shifting, a bent gear lever will also do it. Just clutching at straws!! before you strip it down.
gaz is offline   Reply With Quote
Old 09-28-2008   #4 (permalink)
firemat
firemat's Avatar
yeah the splines were stripped..that was fixed...thats not the problem anymore...it won't downshift is what I am saying...thanks
Mathieu
Old 09-28-2008   #5 (permalink)
tobyone
i think he say if its striped its not postion right so it wont down shift try to pull of and move up
tobyone is offline   Reply With Quote
Old 09-28-2008   #6 (permalink)
firemat
firemat's Avatar
yeah I understand...but its positioned right...the shifter will go down to the end of its movement as a regular shifter does...but will not go down in gears..nothing happens..it stays in 5th
Mathieu
Old 09-28-2008   #7 (permalink)
tobyone
have you try to down shift when like try to bump start it other than that proble tho screrows mesed up ??? good luck you no how to make my bike go foword?????
Old 09-28-2008   #8 (permalink)
firemat
firemat's Avatar
I'm sorry but I don't understand what you mean
Mathieu
POG (Plastic Oil Gear) UnHog Kawasaki Cruisers 16 10-30-2008 02:38 PM
stuck in gear and shifting problems harpgregory Main Lobby 4 01-24-2006 08:56 PM
4th gear problems panosg Kawasaki Motocross and Offroad 1 03-10-2005 10:19 PM
2001 ZX-6R J2 gear lever/clutch problem? MJ The Mechanics Corner 2 11-19-2004 01:05 PM
'01 ZX9R w/busted transmission in FL. $3500 OBO Lunchbox Streetbikes Buy/Sell/Trade 3 10-31-2004 12:37 AM
