Old 09-28-2008   #1 (permalink)
joel_e
Default 2006 kx 125 pilot air screw?
can any one tell me how many turns the pilot air screw should be on a 2006 kx125? thanks
joel_e is offline   Reply With Quote
Old 09-28-2008   #2 (permalink)
Sledder
Sledder's Avatar
Sensitive adjustment that relies on a bunch of variables,..it should be from 3/4 to 2 1/2 turns out when set properly or you need other jetting changes....the correct place to have it is slightly on the rich side of lean for your application. The is no "correct # of turns" ,it gets turned until it is set properly for throttle response/idle speed and proper mixture.
Read up on jetting guide to get you atarted.
04 MS 1640
Thunder 100 in kit/cams
Race ported heads by "dynoray"
Thunder air
V&H Propipe
PC3
Sledder is offline   Reply With Quote
air screw adjustment pididal77 Kawasaki ATV and Mule 1 09-26-2008 10:19 PM
2006 kx 125 idle??? joel_e Kawasaki Motocross and Offroad 7 09-12-2008 06:19 PM
just wanted to confirm something about pilot screw sac600r Kawasaki Streetbikes/Sportbikes 2 09-03-2008 10:50 AM
carb setting KX125 stevem Kawasaki Motocross and Offroad 5 05-12-2008 01:12 PM
Up w/ my ex500 pilot screw leaks fuel "keihin CVK34 plumper40d Main Lobby 3 11-10-2004 09:50 AM
