Old 10-07-2008   #1 (permalink)
igm82
Default piston pin puller
I was going to the top end on a 77 ke250. I've never worked bikes, do I need a piston pin puller? Or can I get it out by some other means? If so can I get one that will work at an auto parts store or do I need one specific for this bike?
igm82 is offline   Reply With Quote
Old 10-07-2008   #2 (permalink)
Fatcat 1
Finally Got Into First Gear
I used a deep well socket to remove my wrist pin I just pushed it through by hand no hammering or forcing involved. However if you feel you have to force it then yes use a pin puller!
Fatcat 1 is offline   Reply With Quote
Old 10-07-2008   #3 (permalink)
KDXGarage
Hey, lemme ride your bike
KDXGarage's Avatar
They usually come out with hand force. Don't buy one until you are sure you need it. DO NOT beat on it. That is a sure way to mess up the connecting rod big end bearings.
www.kdxgarage.com WTB: Kawasaki special tools, 1987 KX250, 1985 KDX80
KDXGarage is offline   Reply With Quote
Old 10-08-2008   #4 (permalink)
gaz
Turtle Wax Taster
the pin can get stuck sometimes, the way I do it is:
get a sliding "F" clamp, (the small ones cost a couple of bucks), put a deep larger that the pin socket on one side of the piston, then put a deep smaller than the piston pin socket on the other side, now using the "F" clamp slowly push the socket through. If the pin is really tight the larger socket will have to be changed for something that won't mark the piston (wood etc). This has never happened as the pin is only usually too tight for taking it out by hand.
gaz is offline   Reply With Quote
Old 10-08-2008   #5 (permalink)
igm82
thanks alot, its a big help
Old 10-08-2008   #6 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
As already said, it should push out easily.
Do not start pounding on it.
If its stuck badly, a shop would likey use their press and push it out for you for free, or very cheap, as its a 1 minute job.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Possible 1700 issue??? Hogbreath Kawasaki Cruisers 15 09-30-2008 12:04 PM
Piston install/break in/jetting info HERE! >>> Lakeshore Kawasaki Motocross and Offroad 0 09-15-2006 01:05 PM
Wrist pin length nitris223 Kawasaki Motocross and Offroad 4 04-10-2006 08:52 AM
Please help! Can't find the right piston!! aaron7 The Mechanics Corner 2 01-29-2006 10:11 AM
