Old 10-13-2008   #1 (permalink)
fuzz_3320
Exclamation i need help!!
my 1999 kx 125 will not start. i replaced the piston and piston ring but still nothin also the plug is fouling out. so i cleand the carb but still nothin. what do u think??
fuzz_3320 is offline   Reply With Quote
Old 10-13-2008   #2 (permalink)
jdager
first, put in a brand new plug, dont try to clean it. most of the time I have a hard time starting it, just changing the plug takes care of it, especially if you know it is fouling anyway. that is what I go by on when to change the plug, when it starts getting hard to start, put a new one in. FYI, if you go somewhere like orielies, they are like a buck 50, instead of almost 5 bucks at the dealer
jdager is offline   Reply With Quote
Old 10-13-2008   #3 (permalink)
snardle
Bob
snardle's Avatar
If u replaced rings you should start with compression check, it takes 3 things to run fuel fire and compression.
snardle is offline   Reply With Quote
