Old 10-14-2008   #1 (permalink)
mikeskickinit
Default fouling plugs on a KX 250..help
Well I recently had my bottom & top end all re-built on my '98 KX 250 and had the carb cleaned as well. Every time I go to start the bike, it either doesn't start at all or it will start and bog down right away and die out...then I need to put a new plug in and then it starts first kick. I tried burning the tip of the old plug etc but it doesn't work.
So every time I go to ride my bike I need to put a new plug in it..Once in a blue moon (like this weekend) I went out and started it 2nd kick and rode it around..Went out the following day and started no problems. Just yesterday (Monday) go outside and it doesn't start at all. I do shut the fuel off when I'm done riding it.
Does anyone know why? I was told it could be something about not setting the plug??
I'm using BR8es plugs in the bike currently. Oil ratio I'm using is 32:1. Any help would be great..thanks!
mikeskickinit is offline   Reply With Quote
Old 10-14-2008   #2 (permalink)
evoluvin
this si what i did... it may help... i mix one small bel-ray H1R to 5 gallons of gas and i also use a hotter plug witch is a br7es.... also make sure when u start it u only leave the choke on for less then a min. also yoou always have to keep reving these bikes and keeping the RPM's up you cant let it sit there idleing... also is your crankcase oil level staying the same? If not it could be crankcase seal.. also take a look at my thread i posted last week... http://www.kawasakimotorcycle.org/fo...help-asap.html
Hope this is some help....
evoluvin is offline   Reply With Quote
Old 10-15-2008   #3 (permalink)
KickassKX125
Now after another 125!!
KickassKX125's Avatar
Send a message via AIM to KickassKX125 Send a message via MSN to KickassKX125 Send a message via Skype™ to KickassKX125
The main reason bikes foul plugs is because they are running rich, changing plug temperature is a quick bodge for if you have no time, take the time to read the jetting guide and jet your bike, it might be a pain in the rear but it is worth it - especially if you ride at the same place or a similar altitude because you won't have to re-jet unless you change either the pipe or reeds .
Jamie
Bought 1996 CR250 but need to pick up.
Now after another Mad Kaw 125 to tear the garden up!
KickassKX125 is offline   Reply With Quote
Old 10-15-2008   #4 (permalink)
mjsedg
Will changing reeds really make that much of a difference. Right now my bike is jetted dead on, but over the winter I plan on doing a top end and a new set of OEM style reeds. Think I'll still need to re-jet?
mjsedg is offline   Reply With Quote
Old 10-15-2008   #5 (permalink)
KickassKX125
If the reeds are going to be the same then it will be ok, what I meant was if you get the boyesen or vforce or any other performance type, sorry I should have mentioned that.
Jamie
Old 4 Weeks Ago   #6 (permalink)
mikeskickinit
Yea, right now I am leaning out mixture. I was doing 3:1....and worked my way down to 2:1 right now and the bike seems it be running better. I am going to ride it today and see if it starts up.
and I did go ahead and jet the bike previously.
Old 4 Weeks Ago   #7 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
2:1 what?
Buy an air/fuel gauge, slap it on, and know what you have for mixture.
They are inexpensive, draw so little power, any bike can run one, and you ae then able to jet it perfectly at every rpm and load.
I put them on all of my high performance bikes.....they are worth their weightin gold, and you will have the piece of mind of a perfect running bike, that you are not going to blow the motor up in.
Riding is good for ones soul.
Riding amongst friends is even better.
Saleenguy is offline   Reply With Quote
Old 4 Weeks Ago   #8 (permalink)
mikeskickinit
2:1....2 ounces of oil, 1 gallon of gas.
I took the bike for a rip Monday. Put choke on started up 2nd kick no problem and ran fine...so far, so good!
Old 4 Weeks Ago   #9 (permalink)
jdager
hi, could you please explain the air fuel gauge and how they work? it seems like an awesome idea, I might like to try one. where does it install, what should the readings be on a 125, and how do you use that to help jet the bike?
thanks,
JIm Dager
jdager is online now   Reply With Quote
Old 4 Weeks Ago   #10 (permalink)
gaz
Turtle Wax Taster
hey if 1 gallon is 128oz then (2oz:128oz) is 1:64 (oil:gas). I wouldn't be running the bike that lean on oil. I run mine at 40:1 (gasil) and thats using Motul 800 oil. You might find the motor running hotter and may eventually seize or need a rebuild sooner.
3.5oz:1 gallon = 40:1 ratio
4.0oz:1 gallon = 32:1 ratio
we use metric so I'm only guessing!
How many oz is a small Belray H1R?? , if its 1 pint then that to 5 gallons is 40:1 which is ok.
Leaning the gas/oil is not the same as leaning the air/premix gas that is done in the carby. Pick an oil/gas mix between (32 - 40 : 1) then work on the carby jetting. Its a pain but worth it when you get it right.
gaz is offline   Reply With Quote
Old 4 Weeks Ago   #11 (permalink)
Saleenguy
Dazed and Confused
Saleenguy's Avatar
thanks,
JIm Dager
The probe goes into the pipe, and then a wire to the gauge.
it gives you instant measure of your air/fuel ratio.
depending on the bike, and your useage, you can run it a little more or less...but about 13 to 14 feels good for me most of the time.
ninja 250 or 650 first bike??? soldier113 Kawasaki Streetbikes/Sportbikes 55 07-27-2008 04:59 AM
2003 kx 250 plugs jpdavis027 Kawasaki Motocross and Offroad 13 03-05-2008 09:41 AM
Bayou 250 motor or 220? Matt R Kawasaki ATV and Mule 5 01-07-2008 09:18 PM
Would you recommend a 600cc supersport to a noob? stefano Kawasaki Streetbikes/Sportbikes 231 12-08-2007 09:37 PM
Spark plugs fouling, and oil ratio damarble Kawasaki Motocross and Offroad 10 05-27-2006 02:21 AM
