Foil Inspector
I would recommend getting a factory service manual. There are two for our bike. A "generic" (85-90 EN400/EN450) and a "specific" (1994-2009 Ninja 500/GPZ500S). Look first in the specific and it frequently refers to the generic for stuff that has not changed.
The most I have gotten into mine is adjusting the valves. I can look up something for you if you wish, but I'm about to call it a night. Brian
'08 Ninja 500 '85 Pontiac Fiero with 4.9l Caddy V8 |
#4 (permalink) |
Honest it wern't me !!
![]() ![]() Join Date: Nov 2006
I assume you mean the Water pump impeller ?
Have you got to the point where you can see the impeller ? If so it is a left hand thread so do it up to undo it..
END OF MESSAGE ! |
#6 (permalink) |
Ok i have included some pics to assist.
1st one shows the impeller removed. [A] Impeller Sealing Seat Surface [b] Rubber Seal [C] Mechanical Seal Diaphragm Which leaves the plate that centralises the impeller shaft and houses the mechanical seal Diaphragm (C) ![]() 2nd pic shows this plate removed to allow access to the mechanical seal. This will also reveal the shaft.. Oh and this plate is located via 2 dowels and will be quite difficult to remove so be very carefull not to break the plate !!! ![]() Hope this helps
END OF MESSAGE ! Last edited by GREENISBEST : 1 Week Ago at 01:27 PM. |
#7 (permalink) |
I have the housing removed already. The shaft is revealed, but I cannot figure out how to remove the shaft.
The parts breakdown makes it look like it is screwed in, but I cannot unscrew it. The reason I am trying to remove the shaft is that its threads broke off into the impeller, so I need a new one. I want to take this one out an install another. I asked my the parts department at my dealer how to do it, and they said they had never done it before on an EX 500, but it is probably held in by clips. However, there are no clips on the exterior surface where I can see the shaft. |
#8 (permalink) |
If i remember right and it's been a while since i had one apart, There is a clip that holds the shaft in the crankcase keeping it engaged with the oil pump drive.
You should see the method by which it's fixed in by removing the oil pan. Just looked a pic i took the last time i had one apart and it looks like it's screwed into the gear that drives the balancer shaft ! I'll have to give it some thought as removing the oil pan may not facilitate removal
END OF MESSAGE ! Last edited by GREENISBEST : 1 Week Ago at 02:42 AM. |
#9 (permalink) |
Here's the pic i mentioned, RED arrow pointing at your impeller shaft.
I'm woundering if the crankcase has to be split to remove the balancer shaft complete with gear before you can remove the impeller shaft or maybe removing the oil pan will enable you to hold that gear whilst undoing the shaft. (Holding it present a new problem of it's own) I will further investigate the method of fixing later at work. ![]()
END OF MESSAGE ! |
#11 (permalink) | |
I have since discovered the impeller shaft is just screwed into the balancer shaft gear. It's a case of get a good hold on the sucker and undo her !!!!!!
END OF MESSAGE ! |
#13 (permalink) | |
END OF MESSAGE ! |
| Too small for a ninja 500? | hordak | Kawasaki Streetbikes/Sportbikes | 62 | 11-15-2007 03:23 PM |
| Ninja 250 & Ninja 500 Power:Weight | MaineKawi | Kawasaki Streetbikes/Sportbikes | 16 | 10-30-2006 12:19 AM |
| ninja 500 wheel help | curtissays | Kawasaki Streetbikes/Sportbikes | 3 | 10-12-2005 12:06 PM |
| Regarding Ninja 500 | I5-FLYER | Kawasaki Streetbikes/Sportbikes | 10 | 09-21-2005 03:43 AM |
| WTB: Kawasaki Ninja 500 | Lzzybeth | Streetbikes Buy/Sell/Trade | 5 | 05-25-2005 09:05 PM |
