Woops I did it again.....
+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 21 to 37 of 37
Thread: Woops I did it again.....
  1. #21
    Propensity for velocity Forum Supporter Tweek's Avatar
    Join Date
    Jun 2006
    Location
    Flower Mound, TX
    Posts
    2,222
    I thought the P1 required warmers. That was basically where I was going: no warmers.
    One thing to watch out for it the change in profile if you go with the Bridgestone. Michelin and Pirelli both have a similar profile. I like the Pirellis.
    As for the number of days I'll use them: two things: budget and riding style. I enter turns too slow and exit really fast and only use moderate amount of lean angle. This puts most of the stress on the center of the rear tire.
    What I'll be working on Saturday and most of the winter will be entering turns faster. This will put more stree on the sides of the front tire.
    The 2CTs I ran this year are now my street tires. The sides of the rear tire are toast, but the center still has some life. The front tire looks fine. but the rubber is grainy. These tires were used from February until October (about 8 track days + 1500 road miles).
    The Pirellis will only see the track. We'll see how long they feel good for. As my pace increased I might have to back off of the 8 thing. Which stinks b/c that makes track days more expensive. I'd hate to have to buy a set of tires every month.
    I am part of a redneck agenda
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #22
    Novice Tank Roller Extreme Forum Supporter NCDave's Avatar
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    No, according to the owner of Sportbike Track Time, the Power Ones don't require warmers and a pretty consistant. That may be only one of the variations of the model though. Look up Power One on the net and they have a site to help you select the "right" tire according to them.
    it also happens to be the tires they sell at Sportbike Track Gear, and they are selling sets for $300. Not too bad a price from what I have found. That's the only reason I'd consider them because I don't want to go the warmer route.
    someone also suggested Pirelli Diablo supercorsas. I just don't have any experience in the world of true sport tires to have any solid ideas of which way to go. That's why I figured I'm safe with what the owner is suggesting.
    My cornering and exiting are BOTH slow, so I'm thinking about running a car tire!
    NCDave
    "Our Lady of Blessed Acceleration, don't fail us now." - Elwood Blues
    http://www.bikepics.com/members/ncdave/
  4. #23
    Join Date
    Jun 2006
    Location
    Flower Mound, TX
    Posts
    2,222
    $300 a set is very good. I might have to give them a look see after the Corsas are done.
    Go with what makes you feel good. I'm actually sorta interested in the Shinko. If they are letting go at lower speeds it might be a good way for me to get a gentle introduction in to drifting corners. Safer than the speed necassary to make a 2CT or Corsa slip. Just as long as the Skinko is gradual and consistent with its slip.
  5. #24
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    I'm running the Shinko 005, which is a sport-tour tire. They make an 003 for sport riding, and also a soft-compound 003 as well. I'm not totally sure what the difference is between them, but they have a pretty good website describing their details.
    The 005 would certainly make for an interesting track day!
    NCDave
  6. #25
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    A couple pictures just before the get-off.....
    I wasn't leading with my head enough.
    NCDave
  7. #26
    Tod
    Tod is offline
    Spinach Eating Moderator Extreme Forum Supporter Tod's Avatar
    Join Date
    Aug 2005
    Location
    Round Rock, TX
    Posts
    22,962
    Admit it...you were looking at the other guy's butt weren't you?
    “Saying what we think gives us a wider conversational range than saying what we know.” - Cullen Hightower
  8. #27
    2009 ZX-6R BTK Expert messer00's Avatar
    Join Date
    Feb 2008
    Location
    California
    Posts
    1,604
    Great pictures !!!
    As for your fall... You either grabbed a little too much throttle coming out of the turn OR that suspension adjustment had something to do with it. I'm far from an expect on the subject, but I personally think that's a pretty large varience between the front and rear. In that part of the turn, a lot of your body weight is over the front of the bike. If those forks compress to much, it makes the back end lighter and you lose traction. Add a slight throttle increase and you get a lowside. You heard the guy. He wanted 30 in both. There's a reason for that.
  9. #28
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    I was running 30. I'm thinking of trying 28.
    NCDave
  10. #29
    Join Date
    Feb 2008
    Location
    California
    Posts
    1,604
    Quote Originally Posted by NCDave View Post
    It was the large varience between the front and rear that I was talking about. A couple of millimeters may not sound like much, but it's quite a lot in terms of suspension numbers.
  11. #30
    Join Date
    Jun 2006
    Location
    Flower Mound, TX
    Posts
    2,222
    2:18.2! about .5 better than before.
    Worked on getting in to the turns faster. In the past I've been getting 'good' times by braking hard and then launching back out hard (shift down to second and run it up to the red line). This time I left the bike in third. You can still get good acceleration but not that good.
    I learned a few things doing this excercise. First: where you look is extremely important. doing a two step helps with this a lot. Looking at the right place helps slow things down and keeps you from feeling like you are going to run off the track.
    The second lesson is: there just isnt any magic to this stuff. want to go fast? just do lots and lots of laps. Good thing I can get out on the track as much as I can: this is going to take a while.
  12. #31
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    Yeah. I was explaining to a couple younger guys today about track riding. It gets easier the more laps you do because you get more and more familiar with each of the turns. Sounds like you had fun! I can read the excitement in your post!
    NCDave
  13. #32
    RIDING LIKE I STOLE IT Forum Supporter V2K_CCTX's Avatar
    Join Date
    Jul 2007
    Location
    Corpus Christi, TX
    Posts
    13,536
    hey Dave...thought this was a brittney spears fan thread by the title
    07 ZX14 Kawi Lime Green (32/50)
    07 VN2000LT White/Ti
    03 BMW 745Li
    00 VW Beetle 1.8T
  14. #33
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    Gee...I wish I had a good comeback for that.
    NCDave
  15. #34
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    I noticed last night that my front fender looks tweeked and not straight on the bike. I'm going to have to take the front end apart to make sure it's ok. I hope I didn't bend anything else.
    NCDave
  16. #35
    Join Date
    Jul 2007
    Location
    Corpus Christi, TX
    Posts
    13,536
    bet brittany could get it straightened out
    03 BMW 745Li
    00 VW Beetle 1.8T
  17. #36
    Join Date
    Oct 2007
    Location
    Concord, NC
    Posts
    15,810
    even bald she could probably accomplish that!
    NCDave
  18. #37
    Made It To Second Gear BTK Beginner
    Join Date
    Oct 2009
    Location
    Roanoke, VA
    Posts
    76
    Ten years ago she could have straightened it out. Too sketchy now.
    Fuel Economy
    99 EN500, $800 on 10/6/09. 2200 miles and counting.
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Woops!
    By Lobocop in forum Kawasaki Cruisers
    Last Post: 09-02-2006, 12:12 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
