LinkBack | Thread Tools |
Finally Got Into First Gear
I'm looking at the owner's manual, the following is what is scheduled for 7,500 miles:
Carburetor Synchronization -check * Idle Speed Check * Throttle Grip Play -check * Spark Plug -clean and gap * Valve Clearance -check * Air Suction Valve -check * Air Cleaner Element -clean Evaporative Emmision Control System (C) -check * Battery Electrolyte level -check * Brake Hose, Connections -check * Brake Light Switch -check * Brake Pad Wear -check * # Brake Fluid Level -check * Fuel Hose Connections -check * K Clutch -adjust Steering Play -check * K Drive Chain Wear -check * # Nuts, Bolts, and Fasteners -check * Tire Wear -check * Engine Oil -change Oil Filter -replace General Lubrication -perform Swingarm pivot, uni-trak linkage -lubricate K Radiator Hoses, connectors -check * * Replace, Add, Adjust, or Torque if necessary (C) California Model only K Should be serviced by an authorized Kawasaki dealer That is an intimidating list. What can I do myself? Where can I find out what/where this stuff is? What do I check for? I'd like to do as much as I can myself.
2002 Kawasaki Ninja 500R FOR SALE 1999 Chevrolet Camaro FOR SALE |
I just got a clymer & it seems sufficient. Do the stuff that seems easy & straightforward first. The biggest deal in tackling repairs/maintenance is confidence (well, after following instructions!) A bike is a great place to start. I just rebuilt my carbs (same bike), never really done that before. Runs great. I say jump on in.
#4 (permalink) |
Banned
Run the title again ans set up a date and time and ask people in the area to show up and learn what is going on...besides the newbies, you will probably get some old timers...IF you were to throw in some "after hours time money/pizza and drinks to follow, you may actually get a couple of area mechanics to asssist and further enhance the community support for their shop."
| 600 mile break-in maintenance check | Spok | Kawasaki Cruisers | 28 | 08-22-2007 11:31 AM |
| Mean Streak 500 mile maintenance help | uf-engineer | Kawasaki Cruisers | 7 | 10-17-2005 02:47 PM |
| 04 Nomad FI - 7500 mile Service | dfgpilot | Kawasaki Cruisers | 5 | 11-02-2004 01:46 PM |
| 600 mile maintenance on a 2003 zx6rr | misterB | Kawasaki Streetbikes/Sportbikes | 2 | 10-18-2004 09:12 PM |
| 600 Mile Maintenance Debacle | cincnorad | Kawasaki Streetbikes/Sportbikes | 7 | 10-12-2004 12:45 AM |
