#2 (permalink) | |
Photographer
You bought a bike and don't know the specs for it?
Engine Configuration Inline Four, 4-Stroke, DOHC Engine Displacement 599 cc Engine Cooling System Liquid Compression Ratio 12.8:1 Combustion Chamber Design Pentroof Valves Per Cylinder 4 Intake Valves Per Cylinder 2 Exhaust Valves Per Cylinder 2 Bore x Stroke 66.0 x 43.8 mm Claimed Peak Horsepower 109 bhp @ 12,000 rpm Claimed Peak Torque 48.5 lbs. - ft. @ 10,000 rpm Measured Peak Horsepower 94.4 bhp @ 12,400 rpm Measured Peak Torque 41.8 lbs. - ft. @ 10,400 rpm Measured Power To Weight Ratio 4.70 pounds per horsepower Engine Redline 14,000 rpm Valve Angle (Included) 12 degrees intake, 13 degrees exhaust (25 degrees) Combustion Chamber Volume 10.2 cc Valve Train Type DOHC, Link-plate Chain Drive, Bucket Followers, Shim-under-bucket Lash Adjustment Valve Adjustment Interval 7500 miles Intake Valve Diameter 27.0 mm Exhaust Valve Diameter 22.6 mm Intake Valve Stem Diameter 4.0 mm Exhaust Valve Stem Diameter 4.0 mm Intake Valve Maximum Lift 9.2 mm Exhaust Valve Maximum Lift 8.4 mm Intake Valve Timing Open BTDC 56 degrees Close ABDC 80 degrees Duration 316 degrees Exhaust Valve Timing Open BBDC 61 degrees Close ATDC 33 degrees Duration 274 degrees Valve Timing Measuring Point 1.0 mm. Fuel Delivery System (4) Mikuni BDSR36R CV Carburetor Venturi Size 36 mm Air Filter Type Dual-element Foam Exhaust System Type 4-2-1 Ignition System Digital Electronic Lubrication System Wet Sump Oil Capacity 3.7 quarts (3.5 liters) Fuel Capacity 4.8 gallons (18 liters) Transmission Type 6-speed, Constant Mesh Clutch Type Multi-plate, Wet Clutch Actuation System Cable Clutch Spring Type Coil Number Of Clutch Springs 4 Number of Clutch Plates 17 Drive Plates 8 Driven Plates 9 Primary Drive Gear Primary Drive Gear Teeth (Ratio) 44/ 89 (2.023:1) Final Drive Sprocket Teeth (Ratio) 15/ 40 (2.667:1) Transmission Gear Teeth (Ratios) 6th 26/ 24 (1.083:1) 5th 28/ 23 (1.217:1) 4th 29/ 21 (1.380:1) 3rd 31/ 19 (1.631:1) 2nd 33/ 16 (2.062:1) 1st 38/ 13 (2.823:1) Transmission Overall Ratios 6th 5.843:1 5th 6.566:1 4th 7.446:1 3rd 8.800:1 2nd 11.125:1 1st 15.231:1 Quote:
www.kawiforums.com
www.buykawasaki.com Type in ZX6R into a search engine and you will find heaps of sites with specs and info. When you visit the kawifroums web site there is a 'search' button there. I found a service manual link there and down loaded a service manual for my 2000 ZX6R. Mind you it was 80MB. And on the buykawasaki website you can get good "hot deals" and browse a manual on line. I hope this helps. Good luck, you've bought a great bike. Corbywan 2000 ZX6R Green Melbourne Australia
Corbywan 2000 ZX6R Green |
| 2002 ZX6r parts for sale !!!! | br3 | Accessory Swap Meet | 9 | 08-16-2009 12:54 AM |
| 2002 ZX6R FOR SALE! | ryan | Streetbikes Buy/Sell/Trade | 1 | 05-20-2005 01:05 AM |
| my new 2002 ZX6r | krissie | Want to show off your ride? | 27 | 04-17-2005 10:59 AM |
| Online manual for 2002 ZX6R | jhanshaw | Kawasaki Streetbikes/Sportbikes | 6 | 03-23-2005 06:05 PM |
