1989 1000 ninja STALLS when put in first gear with clutch pulled ! Bike has been sitting awhile ! HELP
+ Reply to Thread
Results 1 to 6 of 6
Thread: 1989 1000 ninja STALLS when put in first gear with clutch pulled ! Bike has been sitting awhile ! HELP
  1. #1
    Join Date
    Jun 2011
    Posts
    2
    Default 1989 1000 ninja STALLS when put in first gear with clutch pulled ! Bike has been sitting awhile ! HELP
    Bike is running fine in nuetral and stall when put in first gear with clutch pulled ! What can be the prob ? please help thats !
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    No Significant Other BTK Expert MFolks's Avatar
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Default Re: 1989 1000 ninja STALLS when put in first gear with clutch pulled ! Bike has been sitting awhile ! HELP
    Check your side stand switch, it may be out of adjustment of have a broken wire. It's a safety devise to prevent driving with the side stand down.
    Mike Folks
  4. #3
    Alien Test Subject BTK Expert jaseman's Avatar
    Join Date
    Mar 2006
    Posts
    3,509
    My 90 ZX-10 was doing the same thing. Mike is correct, it's most likely the sidestand switch. Spray the plunger with a little WD-40. Sometimes, when they get old and dirty, they stick. Sprayed mine about 3 years ago, and haven't had a problem since.
    03 MeanStreak
    '90 ZX10
    '04 Honda 599
    Ride it like you stole it!
  5. #4
    Needs A Real Job BTK Expert
    Join Date
    Mar 2009
    Posts
    2,898
    Are you saying it stalls the moment you put in gear or when you start to release clutch.
    They are two different problems.
    Post back.
  6. #5
    Join Date
    Jun 2011
    Posts
    2
    Hey thanks alot for the help ! and yes it was that switch it wasn't reading closed and was shutiing the bike down . But ran into another prob, the oil drain has a crack running up the thread ! so the pan will need to be replaced or repair . and then getting gaskets for this bike will probably take forever ! Can you silocone the oil pan ?
  7. #6
    Join Date
    Jul 2008
    Location
    Springfield Mo
    Posts
    10,117
    Mike Folks
+ Reply to Thread
Thread Information
Users Browsing this Thread
  1. Bike Stalls When Clutch Released
    By SeanFaw in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 09-18-2010, 12:31 AM
  2. Loud knock in engine after sitting awhile
    By 2WheelFun in forum Kawasaki Cruisers
    Last Post: 02-14-2009, 09:42 AM
  3. 1989 ninja 1000 seat removal
    By mustangpoo in forum Kawasaki Streetbikes/Sportbikes
    Last Post: 12-16-2007, 01:38 PM
  4. HELP!!! my bike stalls when clutch released
    By phil olseb in forum The Mechanics Corner
    Last Post: 01-16-2006, 09:34 AM
  5. HELP!!! my bike stalls when clutch released
    Last Post: 01-14-2006, 10:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
