brighter headlight bulb?
+ Reply to Thread
Results 1 to 3 of 3
Thread: brighter headlight bulb?
  1. #1
    Finally Got Into First Gear BTK Beginner
    Join Date
    Oct 2004
    Posts
    62
    Default brighter headlight bulb?
    Does anyone know if there is a brighter, higher output whiter headlight bulb available for a 1990 ZX-10? I am looking for something that will plug right in to the factory harness without modifications and without overheating the wiring. Thanks.
  2. Remove Advertisements
    Kawasaki Motorcycle
    Advertisements
  3. #2
    A guy who used to ride BTK Expert jimmyh's Avatar
    Join Date
    Jun 2004
    Location
    Chicago NW Suburbs
    Posts
    319
    I think you answered your own question.
    If you go with a more powerful bulb, it is just going to generate more heat, and melt the wiring (which is only designed for 55-65W). With the added negative that it is not going cast anymore light. It is just going to make your existing beam pattern brighter. Which on a motorcycle is not very large.
    I told someone else, if you want better lighting, by a bike that has better lighting. It all has to do with the optics of the reflector housing.
    Ninja Rider from the past...
  4. #3
    Neo
    Neo is offline
    Sit speling cheker BTK Expert Neo's Avatar
    Join Date
    Sep 2004
    Location
    Huntsville, AL
    Posts
    408
    See if a Sylvania Silverstar lamp is available for your bike. I found one for my Ninja 500R a while back and its great! I don't remember what the wattage is compared to the stock bulb, but I don't think it was much. The major advantage of the Silverstar is the "color temperature" of the bulb: It's a "whiter" light than the standard tungsten bulb. Also, make sure your headlamp is properly aimed. That will go a long way towards increasing your ability to see the road.
    Regards!
    Agent Smith: Goodbye, Mr. Anderson.
    Neo: My name...is Neo!
    2004 BMW R1150 RT
+ Reply to Thread
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
