Foil Inspector
Hey,
Just did my first oil change on my bike myself. Woohoo...everything went well but talk about messy !! The toughest thing, other than getting that damn drain bolt undone, was figuring out how much oil to put back into the bike. I had to put it in, then wait, then put it in then wait, etc.. The waits were to check the oil level. Then when I started the bike, its almost like the oil got sucked into the machine cause the level would get lowered etc, so again the cycle of putting it in and waiting. Anyway now it looks like I have overfilled the oil. Whats the best way to get the oil out, short of opening the drain bolt again ? Any ideas ? I am thinking a long syringe or something. Thanks.
-- I refuse to have a battle of wits with one who is unarmed ! -- |
Foil Inspector
Nope...the oil fills the glass thing completely. I am going to reduce the level out a little but dont wanna have to undo that dang drain bolt again. Have heard abt using a baster with a pipe and so on. Will have to look into all those things.
#4 (permalink) |
Bridal Boutique Manager
why did you start the bike to check the level? drain the oil out and start over. You should have a rough idea of how much to put in from your manual, but some always stays in so don't go strictly by that. With the bike on its center stand or holding it straight up engine off, thats when the level should be between the lines in the window.
#5 (permalink) |
Can't find time to ride
Congratulations on your first oil change
Your owner's manual should tell you how much oil you'll need to put in when you do an oil change. I've found it's pretty accurate. You pretty much did it correctly though. And yes, when you change the filter and start the bike, the oil level will drop. Basically the oil filter holds a small amount of oil all the time, so you need to add a bit after that. With the bike on the center stand, check the oil sight glass. Is the oil level close to or below the "full" line? If so, then you're good. If it's above, then something to suck the excess oil out a little at a time would probably work best (like your syringe or a turkey baster).
Angela '02 ZR-7S Metallic Blue Violet "Bluebird" "I am not pretty baggage! I ride my own!" |
#6 (permalink) |
Foil Inspector
I ended up just pulling the drain plug to get some of the excess oil out and then added a little bit more. Tried the baster thing but no way I could get the pipe attached to it into the casing deep enough to suck the oil out
#8 (permalink) |
I ride what I like
on my 250 if its on the centerstand the glass needs to be half full. If its in wheels then the glass needs to be full. Even when completely full, the engine will suck all the oil out of the glass view.
