LinkBack | Thread Tools |
Finally Got Into First Gear
i tried to get the battery out for winter today but how do i get to it. i took off the plastic black peices on both sides and took off the seat but the battery is under a cross member so what do i do? any help is really appreaciated
On my 05ZX10R you have to slightly raise the rear of the tank, no more the 3 inches so as to not bend the front tank mount, rotate the bracket blocking the battery slightly, then pull out the battery. Helps to have an assistant. I suspect the process might be similiar on your bike.
#4 (permalink) |
Way Too Much Free Time
its basically what he said, the seat comes off, and then it should just come out, i got the manual for the zx6r and it says the same thing, just remove seat, then remove battery.
Check on the sides of the case that battery sits in to make sure not some type of clip holding the battery into place.
2004 Kawasaki ZX6R 636 1995 Kawasaki 600R (old bike) 1991 Plymouth Laser |
