Old 12-22-2005   #1 (permalink)
Ffranzwa
Default '03 KX-250 Throttle
The throttle was sticking on my KX-250, so I replaced it. The throttle worked okay, but it still didn't have that factory-fresh "snap" when I twisted the throttle and let go. After about a month, it is doing the same thing.
-Did Kawasaki have a throttle issue for this year?
-Suggestions on how to fix it.
Thanks
Ffranzwa is offline   Reply With Quote
Old 12-22-2005   #2 (permalink)
hot_shoe_cv
***Vintage Rider***
hot_shoe_cv's Avatar
Here's a couple of suggestions: make sure the grip is not rubbing against the master cylinder body or the other end of the grip is not rubbing against the end of the bar. If it is, just loosen the throttle and slide it back a tad.
If neither of those are the case, then detach the cable, remove the throttle assembly and check for any foreign substance on the bar end or inside the throttle sleeve. Some light lube can be applied to the the bar end before re-assembling. Vaseline is good.
02 Mean Streak, Jardine 2/1 pipe, hiway bars w/pegs, floor boards,ISOgrips w/throttle boss, Kriss head light modulator, Corbin Young Gun ostrich saddle, etc.
660 Yamaha Raptor sport quad for the dirt.
hot_shoe_cv is offline   Reply With Quote
Old 12-23-2005   #3 (permalink)
drifterk
out ridin...are you?
drifterk's Avatar
Vaseline is good.
hahaha its good for a lot of things!!!
88 ex500
gixxer front end
(i bet id keep up with your "big boy" toy)
drifterk is offline   Reply With Quote
Old 12-23-2005   #4 (permalink)
hot_shoe_cv
***Vintage Rider***
Brilliant!
250 Kawasaki ZX-2R Main Lobby 2 06-05-2007 07:45 PM
New to forum, I sell motorcycles, looking to get Ninja 250 TajMan Off Topic 13 07-11-2006 10:45 PM
Throttle died on me at high speed Bodie Kawasaki Cruisers 22 11-07-2005 10:13 PM
question about zx636r throttle bodies ryein7 Kawasaki Streetbikes/Sportbikes 1 11-07-2005 04:38 PM
02' KX 125 Cuts out when throttle is opened quickly dan_dman The Mechanics Corner 2 09-02-2004 07:15 PM
